Fyne Audio F300 Bookshelf Speaker (Used) SOLD
Packing a punch well beyond its diminutive size the versatile F300 bookshelf speaker can be used for two channel Hi-Fi or home theatre applications. Pre-fitted to the rear panel of the F300 is a bracket allowing the speaker to be easily flush-mounted to a wall. This is a really handy feature where space is at an absolute premium, or for using the speaker as a rear effects speaker in home cinema set up.
Spec:
System Type 2 way, rear ported
Recommended amplifier power (Watt RMS) 20 - 70
Continuous power handling (Watt RMS) 35
Sensitivity (2.83 Volt @ 1m) 87dB
Nominal impedance 8 Ohm
Frequency response (-6dB typical in room) 54Hz- 28kHz
Drive unit complement 1 x 125mm multi-fibre bass/ mid 1 x 25mm polyester dome tweeter
Crossover frequency 3.4kHz
Crossover type 2nd order low pass, 3rd order high pass
https://www.fyneaudio.com/product/f300/
Conditions: 9/10 (USED)
Last edited by choyaudiovisual on Fri Jun 02, 2023 12:18 pm; edited 1 time in total
- Number of posts : 5622
» Fyne Audio F1 Bookshelf (SOLD)
» Fyne Audio F500 Speaker (sold)
» Fyne Audio F301 Black Ash Bookshelf Speakers (1 Pair)
» Fyne Audio F501 Floorstand Speaker sold
» Fyne Audio F303 Floorstand speaker (sold)
