Dali Zensor Vokal Centre Speaker (with Box)
Dali Zensor Vokal Centre Speaker (with Box) Empty Dali Zensor Vokal Centre Speaker (with Box)
Post by khthen Fri Aug 05, 2022 5:15 pm
The Dali Zensor Vokal Centre Speaker has been specially designed to match the timbre and tonal balance of its Zensor range counterparts. This centre speaker will cover an essentially important sound zone, said sound zone being where the majority of dialogue from a movie soundtrack will be found. Engineered to cover this zone, the Zensor Vokal will establish a realistic voice and surround experience.
Dali Zensor Vokal Centre Speaker (with Box) Zensor10
Ideally placed beneath your television screen, the sonic integration of the Zensor Vokal is highly convincing. Not only does this speaker boast a perfect sonic integration, but the voice matching between the Vokal and other speakers in the Zensor range is extremely impressive, too. With a front mounted bass reflex port, the Zensor Vokal will seamlessly match the Dali Sub E-12F and will create the sonic illusion that you are truly inside a cinematic experience.
Perfectly matched to the rest of the Zensor series
Front mounted bass reflex port
1 x 25 mm Soft Textile Dome HF driver
2 x 5.25" Wood Fibre Cone LF drivers
Semi Magnetic Shielded.
Review :  https://www.whathifi.com/dali/zensor-1-51/review
Product Specification:
 Speaker Type Centre
 Frequency Range (+/-3 dB)47Hz-26.5kHz
 Sensitivity (2,83 V/1 m) 88.5dB
 Nominal Impedance  6Ω
 Maximum SPL109dB
 Recommended Amplifier Power30-120 watts
 Crossover Frequency24kHz
 High Frequency Driver1 x 25 mm  Soft Textile Dome
 Low Frequency Driver2 x 5.25"  Wood Fibre Cone
Enclosure Type Bass Reflex
 Bass Reflex Tuning Frequency45Hz
Connection inputSingle Wire
Magnetic ShieldingSemi Magnetic Shielded
Recommended PlacementAbove or Below
TV Screen/Projector
Dimensions with BaseH: 161mm
W:441mm
D: 288mm
Weight6.8kg
Price : RM 720.
Condition 7.5/10
Contact : 012-7273382
khthen
Number of posts : 190
Registration date : 2013-09-24
