Starke Sound D7-300 7 Channel Power Amplifier (SOLD)
Starke Sound D7-300 7 Channel Power Amplifier (SOLD) Empty Starke Sound D7-300 7 Channel Power Amplifier (SOLD)
Post by choyaudiovisual Wed Aug 17, 2022 2:52 pm
Starke Sound D7-300 7 Channel Power Amplifier (SOLD) Img_0423
Starke Sound D7-300 7 Channel Power Amplifier (SOLD) Img_0422
Starke Sound D7-300 7 Channel Power Amplifier (SOLD) Img_0424
Starke Sound D7-300 7 Channel Power Amplifier (SOLD) Img_0426
Starke Sound D7-300 7 Channel Power Amplifier (SOLD) Img_0425
Starke Sound D7-300 7 Channel Power Amplifier (Used)
Our A7 amplifier proved to the world that Starke Sound has the ability to manufacture the best multi-channel amplifier currently available in the high-end audio market. Our next challenge was to build and customize a special Class D multichannel amplifier for our H1 Elite and AX architecture series speakers. To this end we partnered with ICEpower to combine their proven power stages with an excellence in power supply, chassis construction, and quality assurance that Starke Sound is known for. After 3 long years of working closely together optimizing and upgrading components we are proud to announce that we have created an amplifier that satisfies in both its construction and most importantly - its performance.
With ICEpower technology and Starke Sound's dedication to produce the finest sound quality we believe the D7 amplifier will deliver the performance you've all been waiting for.
Frequency Response
7 Hz to 20 kHz +/-0.8 dB
Signal-To-Noise Ratio(SNR)
115 dB, “A”weighted
THD+N
0.002% @ 10W (8 ohm, 1kHz, all channels driven)
150W Per Channel @ 0.05% THD+N, 20Hz – 20kHz, 8 ohm
300W Per Channel @ 0.05% THD+N, 20Hz – 20kHz, 4 ohm
Input Impedance
RCA Input: 3.72 kΩ
XLR Input: 3.72kΩ
Input Sensitivity
>3.2 ohm
Output Power
150 W RMS @ 8 Ω
300 W RMS @ 4 Ω
Output Impedance
<0.1 ohm 10 Hz to 20 kHz
Power Consumption
Standby: 1.4W at 115v /1.6W at 230v
Idle: 29W
Maximum: 2100W
Inputs
7 single-ended via RCA connector
7 balanced via XLR connector
12v Trigger input
Power On/Off
Yes
Channel Switches
1/2; 3/4; 5/6; 7 switchable
Dimensions (H x W x D)
3.1 x 16.9 x 10.8 inches
80mm x 430mm x 275mm
Weight
5.6kg (12.3lbs)
Conditions: 8/10 (USED)
Number of posts : 5622
