Wyred4Sound STP SE Preamplifier
Wyred4Sound STP SE Preamplifier Empty Wyred4Sound STP SE Preamplifier
Post by raymond88 Fri Aug 19, 2022 6:21 pm
Item: Wyred4Sound STP SE Preamplifier
Condition: 9.5/10. Item is new but was hidden away in storage for many years. Taken it out to test and everything works like new. Comes with original box, remote, etc.
Price: RM7800 RM7200 or swap/topup
Can Trade-In your Amplifier/
New was RM11k
Wyred4Sound STP SE Preamplifier Wyred410
• Typical Distortion
• THD+N (20-20kHz / 2V) <0.003% THD+N
• Noise (A-weighted / VOL ≤ 63) < 6 µV
• Noise (A-weighted / VOL ≥ 64) < 18 µV
• Noise (20-20kHz / VOL ≤ 63) < 9 µV
• Noise (20-20kHz / VOL ≥ 64) < 27 µV
• Frequency Response
• (20-20kHz / 2V) +/- 0.02 db
• Channel Tracking (All Steps) < +/- 0.05 db
• IMD < 0.002%
• Crosstalk (20-20kHz / VOL ≤ 63) >106 db
• Crosstalk (20-20kHz / VOL ≥ 64) > 96 db
• Output Impedance (VOL ≤ 63) 113 Ω
• Output Impedance (VOL ≥ 64) 78 Ω
• Input Impedance 60.4kΩ
• Maximum Output Voltage 9V RMS
Unit Features:
• Input / Output wiring upgraded to Kimber Tcss wire
• 2nd stage filtering caps (4-22,000uf caps) are upgraded to the Wyred 4 Sound Low ESR "SUPER CAP" designed for power supplies
• Vacuum Fluorescent Display (VFD)
• Optical rotary encoder (volume knob)
• Fully functional remote control
• 12V DC Trigger input (to automatically activate HT Bypass mode)
• 2- 12V DC Trigger outputs
• Home Theater bypass (customizable for any input, also DC Trigger input selected)
• Balance control
• Absolute phase control (0°/180°)
• Efficient (no heat)
• Tripple-ripple reduction circuit contains 164,560uF of capacitance
• Extremely low noise floor
• Fully balanced input to output
• Buffered passive/active design
• Automatically switched in Line Stage (when more volume is needed)
• Discrete volume control using dale RN55d resistors
• Unbalanced to Balanced conversion (when RCA input selected and XLR outputs are being used)
• Idle power consumption = 15w
• Rugged construction
• ½” Machined and Anodized front panels
• 60kΩ input impedance
• 3 sets of gold plated unbalanced (RCA) inputs
• 2 sets of gold plated unbalanced (RCA) outputs
• 2 sets of Neutrik Balanced (XLR) inputs
• 2 sets of Neutrik Balanced (XLR) outputs
• Factory Selectable mains 115/230VAC
• Compact size (17”W x 4”H x 13”D)
• 22 lbs.
Wyred4Sound STP SE Preamplifier Wyred412
Wyred4Sound STP SE Preamplifier Wyred411
Wyred4Sound STP SE Preamplifier Wyred413
https://www.highfidelityreview.com/wyred4sound-stp-se.html
http://www.stereotimes.com/amp082912.shtml
https://6moons.com/audioreviews/wyred2/preamp.html
Number of posts : 10119
Wyred4Sound STP SE Preamplifier Empty Re: Wyred4Sound STP SE Preamplifier
Post by raymond88 Fri Aug 26, 2022 11:57 am
