Procella Audio Centre & Main Speakers Made in Sweden
2 posters
Procella Audio Made in Sweden High-End Modern Speakers for The Best Home Theater & Music Experience (brand RM4700 per unit not per pair).
The new P5 really is an extraordinary speaker! It is almost unbelievable when you are listening to P5 to imagine the size of them, mainly because they sound so much bigger.
Procella P5V delivers the full dynamic range experience to smaller rooms and rooms with multiple surrounds and height speakers.
Still in good condition inside the box, bought extra for additional setup but not in use now due to limited space.
Made by Procella Audio, a famous brand for high-end home theaters and a favorite brand among moviemakers, directors, etc.
Made by DTS Engineers, thus giving the best possible performance. From the group of people who invented DTS sound, nothing more to say about this Procella
Simple design with great quality, technology, and sound quality.
Compression driver technology, where you can get detailed and super clear sound even at the highest volume level.
Very good for both movies and music (hi-fi) use.
https://procella.audio/new-jersey-thx-certified-screening-room/
Please Google for this well-known brand though not so popular in M'sia due to limited dealers and high cost.
https://www.youtube.com/watch?v=jBgnPm8t8UU
https://www.youtube.com/watch?v=88CmUmQa3uQ
https://www.youtube.com/watch?v=w3NEBOP3CSA
https://www.youtube.com/watch?v=TxpR8pi8MZA
web site: www.procella.audio
Using a 1 inch pro audio compression driver for high frequencies for high efficiency and a wider dynamic range than hi-fi speakers using dome tweeters, the P5V is capable of peaks up to 119 dB. Its 80 degree circular constant directivity waveguide produces wide coverage throughout the room. This makes the P5V equally proficient as a main, surround, or height channel speaker.
You can count on the P5V to deliver consistently good sound for all listeners regardless of where the speaker is located and how it is oriented. Multiple mounting options are available, with back baffle threaded inserts for a VESA
100 and keyhole mounts for both vertical and horizontal orientation.
Expanding the highly successful P5 family, the P5V is the slim and sexy wall-mount option. Its softly sculptured enclosure is only 4.1 inches deep, and whether it’s oriented tall or wide, it looks sleekly at home next to both flat panels and projection screens.
Available in both black and white semi matte finishes, there’s no need to hide this speaker behind a fabric wall. Using a 1 inch pro audio compression driver for high frequencies for high efficiency and a wider dynamic range than hi-fi speakers using dome tweeters, the P5V is capable of peaks up to 119 dB. Its 80 degree circular constant directivity waveguide produces wide coverage throughout the room.
This makes the P5V equally proficient as a main, surround, or height channel speaker. You can count on the P5V to deliver consistently good sound for all listeners regardless of where the speaker is located and how it is oriented. Multiple mounting options are available, with back baffle threaded inserts for a VESA 100 and keyhole mounts for both vertical and horizontal orientation.
impedance: 8 Ohms nominal power handling
Continuous 75 WattPeak 250 Watt sensitivity
1m/1W 91dB maximum SPL
free-standing 107dB continuous 113dB peak, in wall 113dB continuous 119dB peak frequency respons
-3dB points 90Hz and 20kHz dispersion pattern
-6dB Constant directivity, 80° circular from 2.5kHz crossover
Asymmetrical and phase-aligned 2.2kHz, BSC connectivity
Gold plated large diameter binding posts wall mount
Inserts for VESA 100 bracket, Keyholes provided for both vertical and horizontal mounting finish.
Black semi-matte painted finish, MDF construction, removable cloth grille, White semi-matte painted finish dimensions and weight
HxWxD 18.5" x 7.5" x 4.5" / 470 x 190 x 115 mm, 11Lbs / 5.0Kg shipping carton
HxWxD 23.6” x 11.6” x 7.9″ / 600 x 295 x 200 mm, 13.2 Lbs / 6.0Kg assembly
Sweden 100% QC testing
Sales price around RM4500 to RM5000 per unit, selling in units not pairs due to high-end stuff with a high price tag as well.
Bought Rm4700 per unit, selling for around RM2900 now (slightly negotiable for serious buyers).
Condition:9/10
Please Whatsapp me at 012-5885270 for more details or photos.
Can arrange personal delivery within Penang, Kedah, KL & Perak areas or can arrange a courier to other places as these units are with original packing/boxes.
Thank you and please stay safe too.
Last edited by anandfm on Sat Apr 29, 2023 9:49 pm; edited 5 times in total (Reason for editing : Revise details)
anandfm- Frequent Contributor
- Number of posts : 984
Procell P5
Available?anandfm wrote:Bump
Danny- New Member
- Number of posts : 1
Registration date : 2023-08-06
» Procella P8 Centre Speaker New MK2 Version (Made in Sweden)-Brand New Inside Box
» Procella Audio 15 Inches Subwoofer from Sweden
» M&K Speakers (S-85s Fronts, S-85C centre), made in USA, Used (Picture's up) SOLD
» Polk Audio Studio Monitor Series 5A Stereo Main Fused Speakers (Sold)
» Entreq Cleanus Ground Box (Made In Sweden)
