Onkyo TX-NR6100 7.2Ch THX Certified Network AV Receiver
Onkyo TX-NR6100 7.2Ch THX Certified Network AV Receiver Brand New. Now Selling At RM5,599. Free Shipping Within West Malaysia.
Massive THX sound and Film-Like 8K resolution
Rigorously tested to receive the coveted THX Select Certification, the Onkyo TX-NR6100 7.2-Channel AV Receiver delivers precision sound and images.
With an emphasis on an enhanced gaming experience, own your opponents with HDMI 2.1 enhancements for gamers: 4K/120Hz HDR pass-through enables ultra-fast motion -VRR (Variable Refresh Rate) eliminates lag, stutter, and frame-tearing for fluid gameplay. – ALLM (Auto Low Latency Mode) optimizes latency from source to screen – QFT (Quick Frame Transport) limits lag for a smoother experience.
Setting the bar for reference sound while bringing 8K video to your compatible display over HDMI:registered: 2.1, you can enjoy Dolby Atmos:registered: and DTS: X:registered: soundtracks through your height-enabled surround system or use upmixing and virtualization solutions from DTS:registered: and Dolby:registered: to create a 3D sound-field from any layout.
Featuring three HDMI outputs and 100 watts of power per channel, the TX-NR6100 AV receiver delivers uncompressed HDMI 2.1 8K 60Hz and 4K/120Hz with HDR over 40 gbps, increasing the bandwidth over its predecessors. This SMART AV Receiver:tm: delivers an unparalleled movie, music, and gaming experience to your living room.
These products support all specs for the 2021 HDMI 2.1 certification. Please ensure your source, TV and HDMI cables are compatible to get the most robust home theater experience possible.
Download the Onkyo Controller App:
*8K60 only valid for Zone 1/Zone 2 will only produce 4K120 resolution when two separate HDMI sources are used.
*Requires third-party AI compatible smart home device with microphone
*Sonos Port required and sold separately
Onkyo TX-NR6100 Specs
Amplifier
Channels 5.2.2
Power Output per Channel 1-Channel Driven:
210 W at 6 Ohms / 1 kHz / 10% THD
2-Channel Driven:
100 W at 8 Ohms / 20 Hz to 20 kHz / 0.08% THD
Dynamic Power per Channel 240 W at 3 Ohms (Front)
210 W at 4 Ohms (Front)
120 W at 8 Ohms (Front)
Frequency Response 10 Hz to 100 kHz +1 dB (Direct, Pure Mode)
THD+N 0.08% (20 Hz to 20 kHz, Half Power)
Speaker Impedance 4 to 16 Ohms
Tone Control Bass (20 Hz): ±10.0 dB
Treble (20 kHz): ±10.0 dB
Audio Processing
DTS Compatibility DTS:X
Dolby Compatibility Dolby Atmos
Auro 3D Support No
Video
Pass-Through Support 4K120p
Upscaling None
Connectivity
Rear A/V Inputs 3 x HDMI 2.1
3 x HDMI 2.0
4 x RCA
1 x Stereo RCA (Phono) with Ground Screw
1 x Optical TOSLINK
1 x Digital Coaxial
Rear A/V Outputs 1 x HDMI
1 x HDMI Zone 2
1 x RCA Zone 2 / Zone B Line-Out
2 x RCA Subwoofer Pre-Out
Front I/O 1 x 1/4" / 6.35 mm Headphone Output
1 x 1/8" / 3.5 mm Microphone Input
1 x USB Type-A Input
Other Rear I/O 1 x FM Coaxial F-Type Input
1 x AM Block Input
1 x RJ45 (Ethernet) Input/Output
1 x USB Type-A (Power) Output
Speaker Connectors 7 x Binding Post Pairs
HDCP Support Version 2.3
HDMI Compression Modes 4K120AB / 8K60AB
Audio Return Channel (ARC) ARC, eARC
HDMI CEC Yes
Media Card Slot None
Bi-Amp Capability Yes
Input Impedance Line: 47 Kilohms
Phono (MM): 47 Kilohms
Input Sensitivity Line: 200 mVrms
Phono (MM): 3.5 mVrms
Rated Output / Impedance Subwoofer Pre-Out: 1 Vrms / 470 Ohms
Zone B / 2 Line-Out: 200 mVrms / 470 Ohms
Signal to Noise Ratio Line: 106 dB (IHF-A)
Phono: 80 dB (IHF-A)
Wireless Connectivity
Wi-Fi Wi-Fi 5 (802.11ac); Dual-Band (2.4 & 5 GHz)
Supported Audio Codecs AAC, SBC, aptX, aptX HD
Wireless Audio Protocols AirPlay 2, Chromecast built-in, DTS Play-Fi
Control
Virtual Assistant Works with Alexa, Works with Google Assistant
Tuner Section
Tuner Type AM, FM
Number of Tuner Presets 40 Stations
Radio Frequencies AM: 530 to 1710 kHz
FM: 87.5 to 107.9 MHz
Power
AC Input Power 240 VAC, 50/60 Hz
Power Consumption Active: 635 W
No Sound: 65 W
Standby: 0.1 W
Physical
Dimensions (W x H x D) 17.1 x 6.8 x 14.9" / 435.0 x 173.5 x 379.5 mm
Weight 21.6 lb / 9.8 kg
- KLIPSCH OPTIMIZE MODE
- HDMI:registered: 2.1 WITH 8K
- ULTIMATE 4K GAMING EXPERIENCE
- THX:registered: CERTIFIED
Klipsch Optimize Mode allows you to easily integrate your Klipsch Reference and Reference Premiere speakers seamlessly with your Onkyo AV receiver. Klipsch and Onkyo teamed up to implement the precise crossover values for specific new Reference Premiere speakers. Now, you can simply select the model speakers you’ll be using for each individual channel, and the optimized crossover setting will be automatically applied.HDMI:registered: 2.1 WITH 8K
HDMI 2.1 is the most recent update of the HDMI spec and supports eARC, a range of higher video resolutions and refresh rates including 8K60 and 4K120, and Dynamic HDR formats. 8K delivers a super-immersive viewing experience with 2x the horizontal and vertical resolution of 4K, and 4 times as many pixels; and combined with 60Hz refresh rate enables smooth and sharp viewing of content with high-speed action. HDMI 2.1 with 8K and eARC ensures your system is ready for the clearest and cleanest picture available both now and down the road.ULTIMATE 4K GAMING EXPERIENCE
Own your opponents with HDMI 2.1 enhancements for gamers: 4K/120Hz HDR pass-through enables ultra-fast motion -VRR (Variable Refresh Rate) eliminates lag, stutter, and frame-tearing for fluid gameplay. - ALLM (Auto Low Latency Mode) optimizes latency from source to screen - QFT (Quick Frame Transport) limits lag for a smoother experience.THX:registered: CERTIFIED
In 1993, Onkyo became the first consumer electronics brand to be THX-certified. With literally thousands of tests, before earning the THX-certification logo: no matter what input is used, no matter what combination of the many built-in features for the AVR, preamplifier, or amplifier, there can be absolutely nothing added, nothing taken away from the source material.BUILT-IN STREAMING SERVICES
Access to Spotify:registered:, TIDAL, Deezer, TuneIn, and Pandora:registered: are built into the system. Use dedicated apps (where available) or the free Onkyo Control App for Apple and Android devices to find and play music.Discrete Zone 2 HDMI Switching
Set up different Ultra High-Definition entertainment options with up to 8K60 resolution* in two different rooms from your Onkyo receiver. Watch a movie in the home theater, while the kids watch cartoons in their playroom.**8K60 only valid for Zone 1/Zone 2 will only produce 4K120 resolution when two separate HDMI sources are used.
SMART HOME COMPATIBLE WITH VOICE CONTROL
Onkyo receivers easily integrate into your existing Smart Home ecosystem, including Apple Airplay, Alexa, Google apps, and more. You get a highly capable and compatible network device that can operate seamlessly in your multi-room ecosystem.**Requires third-party AI compatible smart home device with microphone
WORKS WITH SONOS CERTIFIED
This receiver can join your existing Sonos Home Sound System, or be the start of a new one, just by pairing it with a Sonos Port.* This works with Sonos Certified AVR offers a best-in-class tie-in to the Sonos ecosystem, waking, changing inputs, and playing at the volume you want using the Sonos Volume-Pass Through feature from the Sonos app.*Sonos Port required and sold separately
BI-DIRECTIONAL BLUETOOTH:registered: WIRELESS TECHNOLOGY
This Onkyo AVR can send and receive audio via Bluetooth wireless technology. Stream from your device to the receiver using SBC or AAC codecs, or transmit audio playing through the AVR to compatible wireless headphones using SBC, aptX, or aptX HD codecs including 24-bit audio over aptX HD. The improved data transfer capabilities of the latest generation of Bluetooth ensure clear and reliable sound reproduction so you hear your favorite songs just as the recording engineer intended.READY FOR DTS PLAY-FI:registered:
DTS Play-Fi allows you to enjoy high-quality music from connected online services, networked media servers, and your device library over Wi-Fi:registered: to any number of compatible products using the Onkyo Music Control App for iPad, iPhone, and Android smartphones/tablets. DTS Play-Fi can synchronize the music in every room. Each member of your family can use their own device to listen to their music in a room or group of rooms. DTS Play-Fi lets you structure a comInterested please feel free to contact:
Amplifier
Channels 5.2.2
2-Channel Driven:
Audio Processing
Auro 3D Support No
Video
Upscaling None
Connectivity
3 x HDMI 2.0
4 x RCA
1 x Optical TOSLINK
1 x Digital Coaxial
1 x HDMI Zone 2
1 x AM Block Input
HDMI CEC Yes
Control
Tuner Section
Tuner Type AM, FM
Power
No Sound: 65 W
Standby: 0.1 W
Physical
- Number of posts : 1318
» ONKYO TX-NR747 7.2-CH THX certified, DTS-X & Dolby Atmos Network AV Receiver brand new SOLD OUT
» Onkyo PR-SC5508 THX Ultra2 Plus Certified 9.2-Channel Network A/V Preamplifier
» Onkyo TX-RZ50 9.2Ch THX Certified AV Receiver
» ONKYO TX-SR707 - THX Select2 Plus Certified 7.2-Channel A/V Receiver,
» Onkyo TX-NR626 7.2ch Network AV Receiver
