Rotel A14 MKII Integrated Amplifier + Rotel CD14 MKII CD Player
Rotel A14 MKII Integrated Amplifier + Rotel CD14 MKII CD Player Brand New. Now Selling At RM9,599. Free Shipping Within West Malaysia.
A14MKII
The A14 MKII Integrated Amplifier delivers 80 Watts per channel of Class AB amplification from your favorite sources including analog, digital, PC-USB with MQA, wireless aptXTM and AAC Bluetooth and Moving Magnet Phono stage. Critically tuned power supply, DAC and amplifier circuits ensure the A14MKII will deliver countless hours of entertainment.
Product Description
The A14MKII is the flagship model in the 14 Series family of Rotel products delivering 80 Watts of Class AB amplification into 8 ohm speakers powered by Rotel’s in-house manufactured, oversized toroidal transformer and an array of 4 high efficiency slit-foil bulk storage capacitors delivering an effortless acoustic performance.
A fully redesigned Digital to Analog circuit topology utilizes a Texas Instruments 32-bit/384kHz DAC with exhaustive tuning and hand selection of all critical components delivering a fuller, richer and more balanced presentation of the music. Improvements to the power supply and amplifier gain stages further refine the audio whether you are listening to a big band orchestra or a solo vocalist.
Tone controls provide treble and bass adjustments in 1dB steps up to +/- 10dB personalizing your experience for all music genres, moods and settings with a BYPASS mode eliminating unwanted noise and distortion.
The A14MKII supports your favorite sources including analog, digital, PC-USB with MQA, high-quality wireless aptX:tm: and AAC Bluetooth streaming and even a Moving Magnet Phono stage for vinyl fans.
The A14MKII is certified Roon Tested delivering the best experience using Roon software so you can just enjoy the music. Control system integration is available utilizing Ethernet, RS232, 12V-Trigger and remote IR connections.
Dual 5-way speaker binding posts allow Zone 2 installations with relay-controlled selection of the A-B speaker outputs. The front panel graphic display includes a large volume indication and audio stream information.
The A14MKII is comfortable in any setting delivering countless hours of audio entertainment.
Product Description
The CD14MKII follows Rotel’s tradition of award-winning CD players with innovations to the power supply, and newly tuned acoustic component resulting in a more accurate reproduction of the audio with rich, genuine detail.
Critical Digital to Analog conversion is managed by a premium Texas Instruments 32-bit DAC with independent power supplies eliminating unwanted distortion and isolating motor controls from sensitive audio circuits reducing noise and distortion.
The tray loading CD mechanism, IR remote, front panel controls and graphic display ensure seamless operation.
Bring your CD’s and allow the CD14MKII to showcase your music with stunning detail, clarity, and accuracy.
Rotel A14 MKII
MAXIMUM POWER OUTPUT
150W/Ch (4Ω)
CONTINUOUS POWER OUTPUT
80W/Ch (8Ω)
TOTAL HARMONIC DISTORTION
(THD)
<0.018%
FREQUENCY RESPONSE
Line Level Inputs:
10Hz - 100kHz, ±0.5dB
Digital Inputs:
10Hz - 90kHz, ±2.0dB, Max
Phono Input:
20Hz - 15kHz, ±0.5dB
S/N RATIO (IHF "A" Weighted)
Line Level Inputs: 100dB
Digital Inputs: 103dB
Phono Input: 90dB
DIMENSIONS (W × H × D)
430 × 93 × 345mm
17" × 3.6" × 13.5"
FRONT PANEL HEIGHT
80mm (3.15")
POWER REQUIREMENTS
230 V, 50 Hz
POWER CONSUMPTION
280W
STANDBY POWER CONSUMPTION
<0.5W
NET WEIGHT
8.94kg (19.71lbs.)
BTU RATING (4Ω, 1/8th power)
632 BTU/h
Rotel CD14 MKII
TOTAL HARMONIC DISTORTION (THD)
0.0035% @ 1kHz
FREQUENCY RESPONSE
20Hz - 20kHz ±0.5dB
>118dB
DYNAMIC RANGE
>99dB
DIGITAL TO ANALOG CONVERTERS
Texas Instruments
CHANNEL BALANCE
±0.5dB
CHANNEL SEPARATION
>118dB @ 10kHz
430 × 98 × 314mm
17" × 3.8" × 12.3"
FRONT PANEL HEIGHT
80mm (3.15")
POWER REQUIREMENTS
230 V, 50 Hz
POWER CONSUMPTION
15W
<0.5W
NET WEIGHT
6.51kg (14.35lbs.)
A14MKII
Product Description
CD14MKII
The CD14MKII delivers accurate reproduction of CDs with stunning clarity resolving even the finest details. The Texas Instruments 32-bit DAC is supported by independent power supplies isolating motor controls from sensitive audio circuits reducing noise and distortion. Bring your CD collection and let the CD14MKII deliver performance at its best.Product Description
Rotel A14 MKII
150W/Ch (4Ω)
80W/Ch (8Ω)
(THD)
<0.018%
FREQUENCY RESPONSE
Line Level Inputs:
Digital Inputs:
Phono Input:
Phono Input: 90dB
430 × 93 × 345mm
17" × 3.6" × 13.5"
FRONT PANEL HEIGHT
80mm (3.15")
POWER REQUIREMENTS
230 V, 50 Hz
POWER CONSUMPTION
280W
<0.5W
NET WEIGHT
8.94kg (19.71lbs.)
632 BTU/h
Rotel CD14 MKII
0.0035% @ 1kHz
FREQUENCY RESPONSE
20Hz - 20kHz ±0.5dB
>118dB
DYNAMIC RANGE
>99dB
Texas Instruments
CHANNEL BALANCE
±0.5dB
CHANNEL SEPARATION
>118dB @ 10kHz
430 × 98 × 314mm
17" × 3.8" × 12.3"
FRONT PANEL HEIGHT
80mm (3.15")
POWER REQUIREMENTS
230 V, 50 Hz
POWER CONSUMPTION
15W
<0.5W
NET WEIGHT
6.51kg (14.35lbs.)
- Number of posts : 1336
» Rotel RCD-1572 MKII CD player
» Rotel A12 MKII Integrated Amplifier
» Rotel 931 MKII Integrated Amplifier (Used)
» Rotel A14 MKII Integrated Amplifier
» Rotel RB-1552 MKII Stereo Power Amplifier
