Burson Audio Conductor V2+ Headphone Amp / Pre-Amp / DAC / USB DAC (DSD)
Reference class Head-Fi redefined.
Conductor V2+ of superior sound and more power, setting a new benchmark in the reference class category.
*New high-density winding technique to power transformers
*Redesigned new V6 SS op-amp which is the best sounding op-amp in the world!
*Pure Class A designed with Field Effect Transistors
*Comfortably drive the toughest headphone in the world while delicately handling the most sensitive.
*Flagship XMOS 6 core USB module, the best digital interface on the market.
Pure Class A, the new output stage with the V6 opamp DNA is able to reveal micro dynamic that others can only dream of.
DSP Volume control is built in the Saber 32 DAC, meaning with any digital inputs, volume control is handled by the Saber 32 DAC, bypassing our own PGA2310 volume control.
XMOS module allows for 32bit 346K sample and DSD256 streaming.
Triple low jitter clock structure for highest level of jitter correction.
The conductor V2+ allows you to playback your digital content with the highest level of fidelity regardless of the operating platform.
2x RCA inputs
1x RCA pre amp output
1x headphone jack
Dimension: 265 x 255 x 80 mm
Weight : 7.0kg
Windows XP,7,8,10, MAC OSX
iOS, Android (OTG support)
Supports PCM up to 384kHz, 16,24,32-bits
Native DSD 64/128/256
DSD over PCM of DoP64/128/256
Asynchronous Isochronous
Coaxial & TOSLiNK/SPDIF up to 24bit 192K
“The Conductor V2+ is beautifully made, can drive practically everything, sounds powerful and full of bass while staying lithe and detailed, and the only real fault I can find is those damn blue volume settings. The original was a real star; this one’s a supernova!” – hifiplus.com
“Excellent bullet-proof build with that magical display of volume level through the silver or black facia. Internally well-presented using top end components, including ESS Sabre DAC.
Sound Quality: Impeccable resolution with an open yet tight and detailed presentation. Sound might be a little too bright for some.” – hifipig.com
“Powerful, very detailed, clear and neutral sound with am impressive power reserve.
– Matches al the headphones with ease, no matter their impedance on sensitivity. ” – head-fi.org (raoultrifan)
Great condition, perfect working.
Comes with remote control, power cord (No Box)
RM5,250
Welcome for audition.
*Credit cards accepted.
Subang Jaya ss14
Contact 012 6116917
www.facebook.com/Actsessory/
» Burson Conductor
» Burson Conductor (SOLD)
» sennheiser HD800, Burson Conductor and hiface evo
» (SOLD) Audio-gd C2.2 Headphone Amp incl Burson Supreme Sound V6 Vivid (Used)
» [SOLD] Burson Audio AB160 audio buffer
