YAQIN MS-77T Vacuum Tube Amplifier (Remote Control)
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Empty YAQIN MS-77T Vacuum Tube Amplifier (Remote Control)
Post by raymond88 Thu Feb 16, 2023 12:07 am
Item: YAQIN MS-77T Vacuum Tube Amplifier (Remote Control)
Condition: 9/10. Item is in LIKE-NEW condition. Comes with remote control, manual, extra fuses and original box. Hardly used. Bought new locally RM3699.
Price: RM2200 RM1900 or swap/topup
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Yaqinm10
Features:
1. The transformer is made of Japanese imported audio special oriented silicon steel sheet Z11 (0.35MM thick)
2. "High-strength oxygen-free copper enameled wire" is produced by special layered group firing process (eight layers in total)
3. The output transformer is made of cable paper and yellow wax special film that is recommended by enthusiasts (bandwidth up to 5Hz-40KHz)
Output power: 8.5W + 8.5W (4Ω or 8Ω)
Signal to noise ratio: ≥84db (A weighting)
Distortion: (8Ω) ≤1.5% (1KHz)
Frequency response: 5Hz-40KHz (-2db)
Input sensitivity:
When combined input: 0.2V
Pure rear input: 1V
Load impedance: 4Ω-8Ω
Electron tube: 300B-N×2, 6N8P×2, 12AU7×2, 5Z3P×1
Dimension: length 590mm × width 470mm × height 380mm
Gross weight: 30kg
Maximum power supply: ≤150W
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Yaqinm17
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Yaqinm16
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Yaqinm19
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Yaqinm18
Number of posts : 10045
YAQIN MS-77T Vacuum Tube Amplifier (Remote Control) Empty Re: YAQIN MS-77T Vacuum Tube Amplifier (Remote Control)
Post by raymond88 Thu Feb 23, 2023 12:30 pm
Post by raymond88 Thu Mar 02, 2023 6:33 pm
Post by raymond88 Thu Mar 09, 2023 4:52 pm
Post by raymond88 Thu Mar 16, 2023 9:56 am
Post by raymond88 Fri Mar 31, 2023 9:16 am
