Cambridge Audio Edge W power amplifier (SOLD)
condition : 8.5/10 - complete with original box and dust cover cloth
price : RM10,300RM10,900
contact : 0128027790 (Wong)
· Continuous Power Output : 100W RMS into 8 Ohms; 200W RMS into 4 Ohms
· Hand-picked components – Cambridge Audio selected only those that sound the best
· Twin Toroidal Transformers – huge reserves of power for consistent tonality
· Cambridge Audio proprietary Class XA Amplification - no audible crossover distortion
· Short signal path – only 14 components between you and your music
· THD (unweighted) : <0.002% 1kHz at rated power (8 Ohms); <0.02% 20Hz – 20kHz at rated power (8 Ohms)
· Frequency Response : <3Hz – >80kHz +/-1dB
· S/N Ratio (REF 1W into 8 OHM) : >93 dB
· Crosstalk @ 1KHZ : < -100dB
· S/N Ratio (REF Full Power) : >113 dB
· Input Sensitivity : Input A1-A2 (unbalanced) 1.09V RMS
· Input Impedances : Input A3 (balanced) 47k Ohm; Input A1-A2 (unbalanced) 47k Ohm
· Inputs : Balanced, Unbalanced
· Outputs : Speakers, Loop out
· Max Power Consumption : 1000W
· Standby Power Consumption : <0.5W
· Dimensions : 150 x 460 x 405mm (5.9 x 18.1 x 15.9")
· Weight : 23.6kg (51.9lbs)
price : RM10,300
Last edited by flxwong on Wed May 24, 2023 1:33 am; edited 3 times in total (Reason for editing : to indicate item has been sold)
flxwong- New Member
- Number of posts : 2
Registration date : 2022-01-24
» Cambridge Audio Edge W Power Amplifier (used)
» Cambridge Audio Edge NQ and Edge W with original box (Used)
» Cambridge Audio Edge M Mono Amplifier (used)
» cambridge audio Edge A integrated amplifier
