Quad Artera Stereo Power Amplifier
Quad Artera Stereo Power Amplifier Empty Quad Artera Stereo Power Amplifier
Post by raymond88 Wed Apr 05, 2023 10:23 pm
Item: Quad Artera Stereo Power Amplifier
Condition: 9/10. Item is in pristine condition.  Comes with manual, power cable and original box
Price: RM4800 or swap/topup
https://houseofstereo.com/products/quad-artera-stereo
Quad Artera Stereo Power Amplifier Quadar19
General Description Power Amplifier
Rated Output Power 140W 8 ohm (<1% THD,1kHz)
Total Harmonic Distortion <0.003% (100W, 1kHz)
<0.03% (100W, 20Hz-20kHz)
Frequency Response -0.5dB (20Hz-20kHz, ref. 1kHz)
-3dB (20Hz-70kHz, ref. 1kHz)
Input Sensitivity 980mV(RCA line in)
Input Impedance 10kohm (Balanced)
15kohm (Unbalanced)
Signal to Noise Ration(S/N) 115dB (A weighted, ref. 140W)
Maximum Power Consumption 750W
Inputs 2 x XLR, RCA
Outputs Speaker A+B
Standby Power Consumption <0.5W
Dimensions (W x H x D) 320 x 158 x 338mm
Weight 15kg
Description
Power Amplifier
From the transformer to the input terminals, each section of the Artera has been engineered from the ground up to ensure power, musicality and stability. The Artera Stereo produces 140 Watts RMS per channel – ample power for driving first-class loudspeakers, unfaltering even under high dynamic and transient conditions thanks to the patented Current Dumping technology. Special attention has also been paid to the newly developed balanced XLR inputs. The robust connections are yet another string to the Artera Stereo’s bow, with an incomparable signal to noise ratio.
Artera Series
The Artera’s complete range includes 3 models: Artera Stereo (power amplifier), Artera Play (CD Player / DAC / Preamp) and the Artera Solus (CD Player / DAC / Preamp / Power amplifier / Bluetooth Connectivity)
Each Artera Series model fuses modern digital connectivity with signature Quad amplification technologies. Styled with grace, influenced by classic Quad systems with a modern twist, each Quad Artera system is a beauty to look at, while demonstrating a life-like detail in every track.
Quad Artera Stereo Power Amplifier Quadar17
Quad Artera Stereo Power Amplifier Quadar18
Quad Artera Stereo Power Amplifier Quadar22
Quad Artera Stereo Power Amplifier Quadar20
Quad Artera Stereo Power Amplifier Quadar21
https://pjhifi.co.uk/product/quad-artera-stereo/
Number of posts : 10041
Quad Artera Stereo Power Amplifier Empty Re: Quad Artera Stereo Power Amplifier
Post by raymond88 Thu Apr 13, 2023 1:46 pm
Post by raymond88 Fri Apr 21, 2023 5:11 pm
Post by raymond88 Fri Apr 28, 2023 1:44 pm
