Neat Acoustics Ultimatum XLS Bookshelf Speaker Made In UK
Neat Acoustics Ultimatum XLS Bookshelf Speaker Made In UK Brand New. Now Selling At RM47,699. Free Shipping Within West Malaysia.
Ultimatum – XLS
The ULTIMATUM XLS loudspeaker is a standmount design which adheres to all the principles that have marked out the ULTIMATUM project and given it such enduring success. The ultra-rigid birch-plywood enclosure, innovative baffle-decoupling technology, ‘isobaric’ bass loading and use of twin EMIT ribbon-type super-tweeters are employed here to deliver the ULTIMATUM promise of a lifetime of musical enjoyment.
The enclosure comprises four discrete internal cavities each optimised for purpose. The Mid/Bass tuning is optimal for the main enclosure volume while the HF cabinet is small to increase rigidity and to stop back pressure from the Mid Bass driver adversely affecting the rear chamber of the tweeter. The two EMIT supertweeters are similarly isolated.
A dedicated XLS stand is available as an optional extra. It comprises an Italian black-slate baseplate with steel uprights and a tri-laminate top-plate made from steel/bitumen/steel.
M6 spikes are used to couple the stand to the floor, and adhesive putty is supplied to be used as an interface between the speaker and the stand. The rear upright can be filled with lead shot, dry sand, or similar ballast.
The XLS stand has been designed specifically for the XLS loudspeaker. It makes an ideal partner, allowing the XLS to perform optimally in any environment.
Dimensions: Height: 60cm. Footprint: 24 x 42cm.
Weight: 13Kg each. Shipping weight: 40Kg. per pair.
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
SPECIFICATIONS
HF Unit 26mm SONOMEX Domed XL
Super HF Units 2* EMIT 25mm planar/ribbon
Bass / Midrange 2* 168mm NEATUnit with Aluminium Phase Plug
Dimensions (hwd): 38x22x37cm.
Enclosure type: Multi-chamber, multi-driver array, incorporating isobaric internal cavity, plus upward firing super-tweeters
Sensitivity: 88db/1 watt
Recommended amplifier power: 25 – 200 watts
Impedance: 6 ohms average. Minimum 4 ohms
Weight: 15Kg. each
Shipping weight: 35Kg. pair
FINISHES
STANDARD FINISHES
Ultimatum – XLS
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
SPECIFICATIONS
Weight: 15Kg. each
FINISHES
STANDARD FINISHES
- Number of posts : 1318
» Neat Acoustics Motive SX3 Bookshelf Speaker Made In UK
» Neat Acoustics Ekstra Floorstanding Speaker Made In UK
» Neat Acoustics Lota Xplorer Floorstanding Speaker Made In UK
» Neat Acoustics Momentum SX7i Floorstanding Speaker Made In UK With Feet Kit
» neat acoustics Iota
