Ruark Audio R5 High Fidelity Music System
Ruark Audio R5 High Fidelity Music System Brand New. Now Selling At RM7,399. Free Shipping Within West Malaysia.
R5 HIGH FIDELITY MUSIC SYSTEM
From feedback we know that many love the design and features of R7, so with R5, we have scaled down our flagship model in all but sound to create a system which is simply pioneering. R5 is also multi-room ready and if desired can be wirelessly linked with our MRx, R2 Mk3 and R7 Mk3 to provide beautiful sound all around your home. Perfect on its own or with a TV as a complete home entertainment solution, R5 embodies our rich heritage with our awareness of changing technology in a system that is timeless and built to last.
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
SPECIFICATION
Audio
Frequency response 35Hz – 22kHz
Drivers 2 x 75mm custom full-range polypropylene cone
neodymium satellite drivers, 130mm subwoofer
Amplifier 90W Class AB
Enhancements Bass, treble, sub level, loudness, 3D audio
Digital to analogue Burr-Brown 32-bit 192kHz DAC
Analogue to digital 24-bit 192kHz ADC
Connectivity
Multi-room Synchronised audio on up to 5 devices
Radio DAB / DAB+ / FM with RDS (87.5-108MHz) and
Internet Radio
Bluetooth V4.0, SBC, AAC, A2DP, aptX, aptX HD
Wi-Fi 802.11b/g/n; WEP, WPA & WPA2 security
Ethernet RJ45
Music services Spotify Connect, Amazon Music,
Deezer, Tidal
Media Compatible with UPnP DLNA media servers;
MP3 up to 48kHz 320kbps, AAC up to 96kHz 320kbps,
FLAC* up to 24-bit 48kHz, WAV up to 16-bit 48kHz or
24-bit 44.1kHz, WMA up to 44.1kHz 320kbps
* FLAC files not supported in Multi-room mode
CD player CD, CD-ROM, CD-R/RW discs; MP3, WMA &
AAC up to 320kbps
Line-in Stereo RCA (max 2.3Vrms)
MM phono input Stereo RCA input with integrated
RIAA phono stage (up to 8mV)
Digital input 24-bit 192kHz optical TOSLINK
Line-out Line-level stereo RCA (2.0Vrms)
Headphone 3.5mm jack, 25mW into 16-32 Ohm
USB Fat32 memory stick playback, 5V 1A (5W)
Aerial Removable telescopic
Aerial connector 75Ω F-type connector
Features
Remote control wireless
App control UNDOK (iOS & Android)
Display High-contrast OLED
Alarms 2 (daily, once, weekends, weekdays)
Auto standby Automatic low power mode
Adjustable input levels Line, optical, phono
System languages English, French, German, Spanish
General Specifications
Finishes Rich walnut or soft grey with grey fabric grille.
Signature Edition in piano black lacquer with
anthracite fabric grille. MiE in smoked grey veneer and
wooden slatted grille.
Remote battery CR2032
Box contains R5 High Fidelity Music System, 2m mains
power cable, remote control, remote control battery,
telescopic aerial, aerial spanner, user guide
Power supply Linear 120W amplifier power supply and
25W switch mode logic power supply
Power input 100-120/200-240VAC, 50-60Hz,
250V T3.15A fuse, 2m power cable with 5A fuse fitted
Power consumption 2W standby, 13W nominal
Product dimensions H142 × W520 × D300mm
Product weight 10.0kg
Inner carton dimensions H395 × W615 × D230mm
Packaged weight 12.3kg
Designed for life
Embodying our knowledge of the past with our vision of the future, R5 is the perfect ‘all-in-one’ system for music and design enthusiasts alike.From feedback we know that many love the design and features of R7, so with R5, we have scaled down our flagship model in all but sound to create a system which is simply pioneering. R5 is also multi-room ready and if desired can be wirelessly linked with our MRx, R2 Mk3 and R7 Mk3 to provide beautiful sound all around your home. Perfect on its own or with a TV as a complete home entertainment solution, R5 embodies our rich heritage with our awareness of changing technology in a system that is timeless and built to last.
- Class leading audio with enhanced 3D stereo sound
- Integrated active subwoofer
- Multi-room ready
- Comprehensive Wi-Fi streaming with Spotify Connect
- Support for Tidal, Deezer and Amazon Music
- Multi Format CD player
- Full Wi-Fi capability allows wireless networking and music streaming
- aptX HD Bluetooth receiver
- Internet radio, DAB, DAB+ and FM Tuner with RDS
Connection Heaven
Whether you want to wirelessly stream or want to connect a turntable or TV, R5 has it covered. For direct streaming, R5’s aptX HD Bluetooth receiver provides above CD quality from compatible devices and with a broadband connection you’ll have access to internet radio stations worldwide and an infinite library of music through services such as Spotify, Amazon Music, Deezer and Tidal. Moreover, with both analogue and digital inputs it’s also easy to connect and enjoy other devices. In particular R5 makes a great sound system for TVs.Beautiful Inside Too
We pride ourselves on our visual design but with our high-fidelity heritage, we know that it’s what’s beneath the surface that really counts! We are proud to say that we are hands-on with every aspect of our products design, spending endless hours debating and evaluating to create what we believe are the finest available. As an example, R5 uses a high capacity linear power supply with Class A-B amplifiers and active electronics and equalisation to precisely control the loudspeaker units. This technology is usually only found in specialist high value audio equipment.Synchronised Sound
With its powerful sound R5 will fill your room with music, but with its ‘multi-room’ capabilities it’s easy to wirelessly link and sync with our other internet enabled models such as MRx and R7 Mk3 to provide synchronised sound wherever you want it around your home. Linking and syncing with other units means that you can tailor the sound level around your home, just as you want, so whether you want to relax or party, with R5 you can do all this and more.Intuitive to Control
Our trademark RotoDial controller provides a slick control system which is easy to use and like our flagship R7, R5 also includes a matching remote which mirrors exactly the main controller. Using superior radio communication, the remote does not need to be aimed during operation and sited on a table or sitting in your hand the remote is an ergonomic delight. Also available for iOS and Android devices is our app called UNDOK. This allows full control of R5 and is ideal for managing multi-room set-up and control.Interested please feel free to contact:
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
SPECIFICATION
Audio
Connectivity
Internet Radio
Ethernet RJ45
Deezer, Tidal
AAC up to 320kbps
Features
- Number of posts : 1323
» Ruark Audio R3S Compact Music System
» Ruark Audio R410 Integrated Music System
» Ruark Audio R410 Integrated Music System Bundle with RS1 Subwoofer
» WiiM Mini + Ruark Audio MR1 Mk2 Hi-Fi System Package
» smsl DP3 HIGH-FIDELITY MUSIC PLAYER (Sold)
