KS AV SOLUTION Professional Speaker/TV/Projector Calibration.
Good News for Customers from whole over Malaysia & Singapore.
KS AV SOLUTION will be at your place from October 2023 - December 2023. Book your slots now. Call 019-400 4551
*Now KS AV SOLUTION perform Remote Calibration to All Audioholics from all over the world. T&C Applies*
- Full Setup Home Theatre System
- Audio / Speakers Calibration
- Video/ Projector /TV Calibration
- Home Theatre Diffuser & Acoustic Treatments
- Remote Calibration Available . T&C Applies.
This Weekend JB & Singapore 14/15-10-23. Slots Available.
Call 019-400 4551 .
The goal of calibrating the audio system in your home theatre is to get a smooth, even frequency response at the primary listening position. You also want the correct sounds to arrive at your ears at the correct times. In addition to the primary listening position, you should also be able to get good performance at the other seating locations - No limits. (T&C)
From Our Professional Calibration We will let you know if your system in Optimize Setup. Just give 1 hour we will let you know how your system response to your room. If your are earring the correct Quality Sound or Distortion signal that you might hear it from day one and look good for you but it's not. You only earring 60% to 70% from your System. We will calibrate 100% from your system and make your Home Theatre alive. You can immediately feel it.
Key Steps:
• Client education about audio calibration process and your
system improvements
• Listener location
• Fix connection problems (cable cost is separate)
• Speaker delay setup
• Speaker placement/alignment
• Speaker level calibration
• All speaker phase check
• Bass management setup
• Subwoofer phase setup
• Subwoofer placement
• Fold subwoofer properly into overall system
• Equalization to reduce room/speaker problems
• Critical measurement of the acoustic environment before and after adjustments
• Listen to real recordings for verification and fine tuning
• Acoustic treatment and speaker placement design (if purchased)
Now =AZWuyTgbWg9m27ms5nJEDyIFpJ1NCHk6Ux_Xx37O543u8lQw2Qw2DhwnJbomgITA8d1Y_TpmurrRY6TZ8NSa8ix9gPysuF_JXTxs172y6JwGuyhbPWIhNUU83v-svkZn7LE&__tn__=-]K-R]KS AV Solution
Deepavali Packages Now RM10000.00 - 5.1 Setup. Call now for more info. Including latest 4K player. T&C Applies . It's comes with professional setup and calibration. Make your Astro Player Alive.
Deepavali Packages Now RM20000.00 - 7.2 Setup. Call now for more info. Including latest 4K player. T&C Applies . It's comes with professional setup and calibration. Make your Astro Player Alive.
Elac Varro Premium PS500 15″ Subwoofer - RM5599.00 Only.
Product Details
ELAC Varro Premium Subwoofers: Total Performance Begins With Design
Eliminate the challenges of placement with ELAC‘s AUTO EQ.
ELAC’s new Premium subwoofer series provides unbeatable power and performance with a sleek, modern design. These new models deliver huge performance at an affordable price. With advanced features such as BASH Amplification, Advanced App Control and ELAC’s revolutionary Auto EQ system, the new Premium Series is the perfect solution for completing your home theater or music setup.
Custom Driver Design
Treated paper cone with a large 2.0” voice coil for increased power handling and thermal management, resulting in higher output SPL.
These new high-excursion woofers utilize a lightweight paper cone that has been treated to enhance stiffness and reduce any effects caused by temperature or humidity changes.
All three Premium Series subwoofers feature a large 2” voice coil for increased power handling and thermal management, resulting in higher output SPL.
Custom Designed BASH Amplifier
All seven models utilize BASH technology.
The discrete implementation of these tracking amplifiers allows for maximum voltage swing, providing all the power that is needed and additional dynamic power throughout the entire operating range of the woofers.
Auto EQ and Advanced App Control
Placement of a subwoofer can be challenging. This is because typically they are placed in corners or hidden next to couches causing reflection, peaks or valleys.
The principle of ELAC’s Auto EQ, is to remove the effect of the room by making a near-field measurement and comparing it to a far-field (listening position) measurement.
This allows a greater degree of freedom for placing the subwoofer where it meets all requirements.
As the pioneer of APP-controlled subwoofers, all seven Varro subwoofers include our 3rd generation Sub Control 3.0 App with Auto EQ room correction and easy setup of multiple subwoofers.
Tech Specs
Speaker Type
Bass Reflex
Woofer 15” Treated Paper
Frequency Response
20Hz to 150Hz (Anechoic)
16Hz to 150Hz (In-Room)
Maximum Output Level, SPL dB/1m anechoic
115 dB
Low Pass Crossover
40Hz to 150Hz
Amplifier Power
500/1000 Watts
App Controlled (BLE)
iOS and Android
Amplifier Topology
BASH
Standby Power Consumption
< 0.5 Watts
Inputs
RCA Line Level, Speaker Level
Data Connection
USB (Firmware Update)
Cabinet Finish
Black Vinyl
Included Accessories Grille, AC Power Cord, Spikes
Dimensions (H x W x D) 480 mm x 460 mm x 460 mm
Net Weight 25.9 kg
KS AV Solution - South
Audio & Home Theatre Demo
3, Jln 14/47, Seksyen 14, 46100 Petaling Jaya, Selangor.Malaysia.
Do Visit us for more full experience.
Person to Contact : +6018-3698826 / 019-400 4551
Monday to Friday 9.00am - 6.00pm.
Saturday / Sunday - Call for Demo.
KS AV Solution - North
Home Theater Demo .
37, Jalan Villa Tanjung Permai 3, Villa Tanjung Permai Batu Kawan. Bandar Cassia . Batu Kawan. Penang.
Person to Contact : 019-400 4551 / +6018-3698826
https:=AZWuyTgbWg9m27ms5nJEDyIFpJ1NCHk6Ux_Xx37O543u8lQw2Qw2DhwnJbomgITA8d1Y_TpmurrRY6TZ8NSa8ix9gPysuF_JXTxs172y6JwGuyhbPWIhNUU83v-svkZn7LE&__tn__=-]K-R][You must be registered and logged in to see this link.]
=AZWuyTgbWg9m27ms5nJEDyIFpJ1NCHk6Ux_Xx37O543u8lQw2Qw2DhwnJbomgITA8d1Y_TpmurrRY6TZ8NSa8ix9gPysuF_JXTxs172y6JwGuyhbPWIhNUU83v-svkZn7LE&__tn__=*bH-R]
Like
Comment
Share
Call 019-400 4551 .
Key Steps:
system improvements
• Listener location
Product Details
Tech Specs
Speaker Type
Bass Reflex
Frequency Response
115 dB
Low Pass Crossover
40Hz to 150Hz
Amplifier Power
500/1000 Watts
iOS and Android
Amplifier Topology
BASH
< 0.5 Watts
Inputs
Data Connection
Cabinet Finish
Black Vinyl
Net Weight 25.9 kg
Home Theater Demo .
+8
=AZWuyTgbWg9m27ms5nJEDyIFpJ1NCHk6Ux_Xx37O543u8lQw2Qw2DhwnJbomgITA8d1Y_TpmurrRY6TZ8NSa8ix9gPysuF_JXTxs172y6JwGuyhbPWIhNUU83v-svkZn7LE&__tn__=*bH-R]=AZWuyTgbWg9m27ms5nJEDyIFpJ1NCHk6Ux_Xx37O543u8lQw2Qw2DhwnJbomgITA8d1Y_TpmurrRY6TZ8NSa8ix9gPysuF_JXTxs172y6JwGuyhbPWIhNUU83v-svkZn7LE&__tn__=*bH-R]
See insights
Boost a postLike
Comment
Share
Kalai7275- Regular
- Number of posts : 90
» Professional Speakers Calibration & Projector Calibration Taiping&IPOH
» Professional Speakers Calibration & Projector Calibration Taiping & Ipoh
» Ipoh / KL Professional Speakers Calibration & Projector Calibration 26/27-08-23
» Speaker Calibration & Projector Ipoh / Shah Alam /Kajang/ SS15 Subang Jaya/ KL
