Dali Oberon 1C Wireless Active Compact Stereo System
- NEW RM4999.00 With Professional Calibration
Easy to set-up. Plug & Play. No speaker cables. Place the speakers anywhere you want too. Simply plug in the power cables into your speakers and enjoy your music/ movies completely wirelessly. Incorporates all benefit from the award-winning Oberon passive series, 1C active bookshelf speakers are fine-tuned by Dali experts to get the best out of the drivers which result in an audio performance that exceeds what you would expect at this price point.
Review: =AT3DuBPRKUveBHT4vblJYNb3dxSvmBDKrUzYmxAbRD-17P6Ej0E5s07WSdP2Khc1M75dZi1QOQsaKyAHypCYQgzezIlIGvkO-bUp9sijZJ5kdYBwPKH56lhaXYyil-6nzoGQYOjkfdkhk6JIJvbAE71ywkEoyQ][You must be registered and logged in to see this link.]
Best active speakers 2023: budget to premium
Product Details
This compact speaker is the perfect match for those looking for great, cable-free sound in smaller rooms where space is at a premium. The DALI OBERON 1 C is part of our high-performance ecosystem of wireless active speakers and amplifiers.
Easy to Position
The wide dispersion pattern of the drivers ensures well-integrated sound that drastically reduces off-axis harmonic distortion.
Low Latency
The SOUND HUB COMPACT uses a proprietary 30-bit wireless protocol to transmit to OBERON C with a typical latency of less than 15 ms.
Patented SMC
The woofer magnet's iron pole-piece includes a patented SMC disc that greatly reduces mechanical distortion for a relaxed midrange and lots of detail.
Active Speaker
Each driver is powered by a dynamic, closed-loop, 50 Watt peak, Class D power amplifier for exceptional sound quality.
Wireless Hi-Fi Sound - Part of the DALI EQUI ecosystem
With quality and convenience at its core, the OBERON 1 C is quick and easy to set up – all you need to do is connect it to our DALI SOUND HUB or SOUND HUB COMPACT and add music. With the DALI EQUI ecosystem of active wireless speakers, music lovers and audiophiles no longer have to choose between incredible sound quality and convenient integration. Listen to music via Bluetooth, CD, Internet radio or turntable, or integrate this great sounding compact speaker into a multichannel surround sound setup.
Reducing Distortion - DALI's patented SMC (Soft Magnetic Compound)
The use of SMC (Soft Magnetic Compound) in the OBERON 1 C greatly reduces mechanical distortion caused by hysteresis and eddy currents. The result is a magnet motor system with a drastic reduction in third-order distortion, which allows the OBERON 1 C to deliver extended listening pleasure, a relaxed midrange and a surprising amount of detailing in its class.SMC-equipped drivers are also particularly well suited to speakers with active amplification, like the OBERON 1 C.
Class D Amplification - Reproducing the smallest details with clarity and accuracy
The OBERON 1 C power amplification comprises two 50 watt-peak, closed-loop, Class D power amplifiers chosen specifically for their sound quality and dynamic ability. One amplifier powers the high-frequency driver, while the other powers the bass/mid driver. The 100 dB signal-to-noise ratio of the power amplifiers ensures that even the smallest detail in a quiet musical passage is reproduced with clarity and accuracy.
Wood Fibre Cone -Revealing the minutest details
The 5ΒΌ" low-loss bass/midrange driver used in the OBERON 1 C features our proprietary fine paper pulp and reinforced wood fibre composite diaphragm, which creates a stiff, lightweight structure. In combination with a low loss surround and spider suspension, the woofer reproduces the minutest details, unfiltered and with high accuracy. It also features an advanced copper-coated aluminium voice-coil wire and our unique SMC (Soft Magnet Compound) magnet technology.
Optimised Cabinet - Constructed from CNC-machined high strength MDF panels
The OBERON 1 C cabinet is constructed from CNC-machined, high strength MDF panels and finished in a variety of wood-effect or matt white laminates. Strategically positioned damping materials inside the cabinet maximise midrange performance without degrading the bass transient response and bandwidth. When it comes to placement, the OBERON 1 C can be stand-mounted using the DALI CONNECT Stand E-600, integrated into AV furniture, placed on a shelf or mounted on a wall using the rear keyhole slots.
Dec 2023
Singapore December Slots - Closed.
Date : 16\17 - 12-23 - Closed.
For Northern State: Sungai Petani / Alor Setar / Gurun
23-12-23 Saturday - 1 Slots Available
24-12-23 Sunday - Closed
Ipoh / KL / JB
30-12-23 - 1 slot Available
31-12-23 - 1 Slot Available.
Due to High Request. We are opening slots for Jan 2024
Ipoh & KL - Start From RM8++
06-01-2024 - 2 slots
07-01-2024 - 2 slots
Seremban / Melaka / JB - Start From RM8++
13-01-2024 - 2 slots
14-01-2024 - 2 slots
Singapore - Start From RM9++
20-01-2024 - 2 slots
21-01-2024 - 2 slots
Sungai Petani & Alor Setar - Start From RM8++
27-01-2024 - 2 slots
28-01-2024 - 2 slots
Call for Weekdays Slots. 0194004551.
KS AV SOLUTION going whole Malaysia & Singapore. If we miss others States call now for slots : 0194004551
KS AV SOLUTION
- Full Setup Home Theatre System
- Audio / Speakers Calibration
- Video/ Projector /TV Calibration
- Home Theatre Diffuser & Acoustic Treatments
- Karaoke Setup
- Stereo System Setup
- Professional Remote Audio Calibration Available - T&C Applies
Note : We can Remotely calibrate your Lovely Home Theatre whole over the Malaysia and Overseas. Price start from RM350 only. T&C Applies . 019-400 4551
KS AV SOLUTION Professional Speaker/TV/Projector Calibration.
Audio & Home Theatre Demo
37, Jalan Villa Tanjung Permai 3, Villa Tanjung Permai Batu Kawan. Bandar Cassia . Batu Kawan. Penang.
Do Visit us for more full experience.
Person to Contact : 019-400 4551
https:=AZV1rxLDfA96vumul2E-NBxXBt4Fw1ZNsTC-l6lfdzZNXrhtcU3zxUF0wSriciCoaB90eeE9GWBT9cb5rc_CB2dirDnZpDvYBBPlSsQmVaI-01mg2G7F_LxM0au4H6hTQFo&__tn__=-]K-R][You must be registered and logged in to see this link.]
Monday to Friday 9.00am - 6.00pm.
Saturday / Sunday - Call for Demo.
Product Details
Easy to Position
Low Latency
Patented SMC
Active Speaker
Dec 2023
Ipoh / KL / JB
KS AV SOLUTION
- Karaoke Setup
Kalai7275- Regular
- Number of posts : 89
» DALI OBERON 3 Bookshelf Speaker
» Dali Oberon 5 speakers
» DALI OBERON 5 Floor Standing Speaker
» DALI OBERON 7 Floor Standing Speaker
» Dali Oberon Grand Vokal Center Speaker
