BMB KSP12s+ Karaoke Package
BMB KSP12s+ Karaoke Package Brand New. Now Selling At RM22,299. Free Shipping Within West Malaysia.
A subwoofer for karaoke developed by karaoke maker BMB that pursues comfortable singing.
By adopting a triangular bass reflex hole, you can make a speedy beat even though it is a bass reflex type.
In addition, the height of the main body can be lowered, resulting in a compact housing.
Selling point
Cabinet made of high quality birch plywood assembled by box joint.
The tough structure keeps outputting powerful sound stably.
Clear high frequency sound by fine-tuned diaphragm
Selling point
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
BMB WB-5000S
SYSTEM
Type Unidirectional dynamics UHF Wireless microphone system
Frequency Range 640Hz - 690Hz
Channel 200CH
Frequency Response 100Hz - 10Hz
Effective Distance 50m
Frequency Interval 250KHz
Frequency Width 50MHz
Frequency Oscillation Mode PLL Module locked loop design
Radio Frequency Sensitivity -90dBm
Total Harmonic Distortion < 5%
Dynamic Range >70dB
RECEIVER
SNR ≥50db
Frequency Stability ±5KHz
Signal Pick Up CPU controlled selection & pilot identification
Mute Mute & Lock Loop Circuit
Disply LCD
DC Input 12V DC ≥1000mA
Output Impedance 600Ω
Output 2 XLR Balance Socket + Unbalance TRS 6.3mm Socket
Dimensions (mm) 420(W) x 44(H) x 160(D)
MICROPHONE
Frequency Oscillation Mode PLL module locked loop design
Transmission Method CPU controlled carried wave & pilot identification
RF Stability ±5KHz
Display LCD+color backlit
Capsule Dynamic
Power Level Hight & Low
Power Supply 2 Pcs AA Battery
Weight 0.55KG
Dimensions (mm) 50(Φ) x 247(L)
BMB CSW-115
System Type 1 Way 1 Speaker Bass Reflex
Frequency Range(-10dB) *1 45Hz~3.1kHz
Frequency Response(±3dB) *1 50Hz~3.0kHz
Sound Pressure Level *2 93dB
Impedance 8Ω
Max Sound Pressure Level *3 120dB(Peak 126dB)
Power Capacity Continuous 500W, Program 1000W, Peak 2000W
Dimensions(H×W×D) 465mm×580mm×488mm (18.3"×22.8"×19.2")
Shipping Dimensions(H×W×D) 597mm×706mm×615mm (23.5"×27.8"×24.2")
Net Weight 24.0kg(52.9lbs)
Shipping Weight 30.6kg(67.5lbs)
Input Connectors Speaker Connector(4P)×2
Pole Mount Cap Φ36mm(1.4"), Depth 96mm(3.8")
LF Driver 380mm(15.0") Cone, 75mm(3.0") Voice Coil×1
Enclosure Construction 15mm(0.6") Plywood
*1 Full space (4π) conditions
*2 1w1m on-axis, swept-sine in anechoic environment
*3 Calculated
BMB DAD-500
Stereo mode 500W @8ohms 1kHz
Stereo mode 700W @4ohm 1kHz
Bridge mode 1000W @8ohms kHz
Sensitivity 530mV @8ohms 1kHz
Frequency Response +-0.3dB @20Hz-20kHz
Total Harmonic Distortion 0.02% @8ohms 1kHz
Signal to Noise Ratio >=103dB @A-weighted
Intermodulation Distortion <0.05% @8ohms 60Hz-7kHz
Damping coefficient >=250 @8ohms 100Hz
Voltage gain 40+-2dB @8ohms 1kHz
Channel separation >=85dB @8ohms 1kHz
Input Impedance 20k ohms @1kHz balance
Power consumption AC power 220V-240V 50/60Hz
Consumed power 1900W
Product dimension 482mm x 423mm x 89mm
Packaging dimension 568mm x 538mm x 160mm
Net weight 19kg
Gross weight 22kg
BMB CSP-612
System Type Two-Way loudspeaker, bass reflex
Frequency Range(-10dB) *1 58Hz~20kHz
Frequency Response(±3dB) *1 110Hz~20kHz
Sound Pressure Level *2 96dB
Impedance 8Ω
Max Sound Pressure Level *3 122dB(Peak 128dB)
Power Capacity Continuous 400W, Program 800W, Peak 1600W
Dimensions (W)378mm×(H)625mm×(D)408mm
(14.9"×24.6"×16.1")
Shipping Dimensions (W)480mm×(H)735mm×(D)510mm
(18.9"×28.9"×20.1")
Net Weight 26.7kg(58.9lbs)
Shipping Weight 30.3kg(66.8lbs)
Pole Mount Cap Φ36mm(1.4"), Depth 75mm(3.0")
Speaker unit LF Unit:300mm(12.0") Cone, 75mm(3.0") Voice Coil×1
HF Unit:25mm(1.0") Throat, 44.4mm(1.7") Voice Coil×1
Accessories Owners manual
Registration card
*3 Calculated
BMB KSP-100
Mic Input: 4 systems
Audio Input: 3 systems (KARAOKE, AUX1, AUX2)
Video Input: 3 systems (KARAOKE, AUX1, AUX2)
Video Output: 3 systems
Output Connectors: 5.1 Channel systems (XLR type)
Sampling Rate/Bits: 44.1kHz / 24bits
Frequency Response: 20Hz ~ 20kHz
Control Connecters: USB (B type) RS-232C (DB-9 type)
LCD Display: 128x64 dots Black and White
DC Input: DC9V
AC Input: Adaptor (AC100V ~ 240V)
Dimensions (mm): 420(W) x 44(H) x 167(D)
Weight: 2.0kg
BMB WB-5000S
UHF Wireless Microphone System- By adopting a high-performance microchip and suppressing distortion, we realized a unique wireless quality microphone unique to BMB.
- It uses high-quality liquid crystal, it is easy to see in any installation situation.
- When the microphone dropped, The microphone will become mute.
It will not occur the Large volume Noise, when falling more than 20 cm. - New function that microphone automatically connect to receiver by shaking microphone. (WB-5000 / WM-500)
BMB CSW-115
CSW Series
Make your singing more comfortable and enjoy your beat.A subwoofer for karaoke developed by karaoke maker BMB that pursues comfortable singing.
Selling point
- Triangle Bass Reflex
Will provide comfortable and speedy beat. - Pole Mount
Add speaker on the top of subwoofer via pole.
BMB DAD-500
DAD Series
Standard power amplifier for PA speaker.- Circuit safety protection will prevent damage in case of accident.
- Case size is standard 2U.
- Switch 2 type of output system. (Stereo / Bridge)
Selling point
- Designed for PA speaker.
- High power, 1800W x 1ch. (DAD-950)
BMB CSP-612
CSP Series
BMB Sound everywhere, PA type speaker Tuned for valious scene use.Cabinet made of high quality birch plywood assembled by box joint.
Selling point
- A new type of vocal and music mixing style. Not only for KTV, but also for Bar, Club, Restaurant, various scene.
BMB KSP-100
Highlight- PC Editor is provided to setup each sound parameter. (EQ, Comp, etc.)
- This model can create the best Karaoke sound for any room or hall utilizing sound editing software via computer.
- The voice effect feature - HANAMICHI - is pre-installed so the orchestra sound shifts from side to side while the singer stays in the center. (KSP-100)
- The Room Acoustic feature is installed to automatically adjust the sound field to all environments depending on the shape of the room and material of the walls, the floor and the ceiling. (KSP-100)
- An Anti-Feedback feature is used to ensure the best indoor feedback control.
- KSP-100 is made in Japan.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
BMB WB-5000S
SYSTEM
Channel 200CH
Dynamic Range >70dB
RECEIVER
SNR ≥50db
Disply LCD
MICROPHONE
RF Stability ±5KHz
Capsule Dynamic
Weight 0.55KG
BMB CSW-115
Impedance 8Ω
*3 Calculated
BMB DAD-500
Net weight 19kg
Gross weight 22kg
BMB CSP-612
Impedance 8Ω
(14.9"×24.6"×16.1")
(18.9"×28.9"×20.1")
Registration card
*3 Calculated
BMB KSP-100
DC Input: DC9V
Weight: 2.0kg
- Number of posts : 1323
» Pro Ktv MK5 Karaoke Package
» BMB CSJ-06 Karaoke Package
» BMB CSJ-08 Karaoke Package
» BMB CSJ-10 Karaoke Package
» BMB CSJ-12 Karaoke Package
