CEC CD3300 CD Player
In good condition 8/10
Made in Japan.
Compatible remote control.
Balanced XLR and Single ended RCA outputs.
Digital outputs of AES, Coaxial and Optical.
LEF Class A output stage.
Selling for RM1390
Contact Peter 012-3820333
Equipped with CEC's own LEF amplifier.
No NFB loop and pure class A circuit operation to suppress signal degradation.
Low-distortion information transmission has been realized by fully balancing the signal processing circuit.
The D/A converter uses a Bar-Brown PCM1738D/A converter for 24bit/192kHz.
The PCM1738 uses the advanced segment method, which is a combination of the multi-bit method and the delta-sigma method, and has excellent dynamic range characteristics.
In addition, by improving clock jitter tolerance, we are pursuing sound quality without the so-called digital smell.
By separating the power supply for the mechanism part and the D/A conversion part, stability is improved and mutual interference is eliminated.
AES/EBU (XLR) EBU (XLR) is also installed.
It also has both unbalanced and balanced analog outputs, making it possible to connect a wide range of digital devices.
Made in Japan.
Selling for RM1390
Last edited by peterclting on Sun Apr 14, 2024 5:55 pm; edited 1 time in total (Reason for editing : price reduced)
- Number of posts : 2486
Re: CEC CD3300 CD Player
price reduced
» C.E.C. CD3300 CD player (Used)
» CEC CD3300 CD player (Used)(sold)
» CEC CD3300 cd player SOLD
» CEC CD3300 CD Player - withdrawn
» Beogram CD3300 CD Player with TDA1541 DAC (SOLD)
