Monitor Audio Gold 50 Speakers (Dark Walnut)
Item: Monitor Audio Gold 50 Speakers (Dark Walnut)
Condition: 9/10. Item is in like-new condition. No dents or scratches. Comes with original box and packaging.
Price: RM3800 or swap/topup
Product description
The bass driver exhibits the low frequency extension and power handling of a much larger transducer while the excellent C-CAM ribbon soars beyond conventional tweeter domes to a stratospheric 60k Hz. Consequently the Gold 50 combines the frequency range of the finest studio monitors with dynamics that defy its modest dimensions.
Optional, dedicated floor stands are available, which can be filled to provide the ultimate foundation for the best possible sound quality.
This product is now available to use with home theatre design software, The Cinema Designer.
Technology
C-CAM ( Ceramic-Coated Aluminum / Magnesium ) ribbon transducer design – providing extension to a class leading 60K Hz
HiVe II port technology for better transient response and tighter bass
New C-CAM RST ( Rigid Surface Technology ) bass / mid-range driver
Single bolt through driver fixings for improved bracing, rigidity and driver / baffle de-coupling
Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
Pureflow Silver internal cabling
Selected premium quality wood veneer or high gloss lacquer finishes
Rigid 20 mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
Invisible magnetic grille fixing provides clean visual styling when used with the grille off.
System Format: 2-Way
Frequency Response: 55 Hz — 60k Hz
Sensitivity ( 1 Watt @ 1 Meter ): 86 dB
Nominal Impedance: 8 ohms
Maximum SPL: 109.8 dBA
Power Handling ( RMS ): 100 Watt
Recommended Amplifier Requirements: 50 — 100 Watt
Bass Alignment: Bass reflex - HiVe II port system
Crossover Frequency: 2.3k Hz
Drive Unit Complement:
1 x 51/2" RST II bass / mid-range driver
1 x C-CAM H.F ribbon transducer
Cabinet Dimensions: ( H x W x D ) 11 13/16" x 6 11/16" x 10 3/8"
Weight (each): 16 lbs 8 oz
Product description
Technology
» Monitor Audio Gold 50 Speakers (NEW*)Dark walnut
» Monitor Audio Gold 50 Bookshelf (NEW*)Dark walnut
» Monitor Audio Gold 50 DARK wall nut B/shelf speakers
» Monitor Audio Monitor 7 Gold bookshelf speakers (sold)
» Monitor Audio Monitor 7 Gold Bookshelf Speakers (Sold)
