SUPRA PLY 3.4/S SPEAKER CABLE 3 METER PAIR
3 METER PAIR
8 BANANA PLUG
RM 489
PHONE : 011-16684141
COD JOHOR BAHRU
Ply series loudspeaker cables, by Supra Cables.
Supra Ply 3.4S is a screened, large-section, low resistance cable which overcomes the usual limitations associated with increased cable size (inductance and increased oxidation) by using a proprietary pure tin plating. The unique square-shaped design is the result of mangled braid cores laid out on top of each other, which reveals the potential of dynamics and transients of your AV system. It also reduces interference and interaction distortion.
Besides significantly improving on the sound quality of most systems compared to cheaper, inferior grade cables, Supra Ply is also ideal for outdoor use, or in automobile, car, truck, and even marine applications, where salt water may quickly corrode a pure copper cable. Ply 3.4S is extremely well suited to medium-to-high resolution systems.
Screened / shielded cables both radiate and pick-up less noise compared to non-shielded. When installation environment gain from maximal noise immunity, Supra shielded speaker cables are the perfect choice.
The result is immediately lowered noise floor and increased dynamics of the hi-fi system. Especially the so called micro dynamics; tiny notes, phrasing, the small differences which make music come alive and not sounding artificial will appear and suddenly stand out from a pitch black background, free from noise, a truly remarkable discovery for most music lovers.
Ply 3.4S is available with Ice Blue coloured outer insulation only.
Please note this is a SINGLE WIRE cable. For a stereo pair (left / right), please order two (x2) units.
3 METER PAIR
8 BANANA PLUG
RM 489
COD JOHOR BAHRU
- Brand: Supra Cables
- Range: Ply
- Type: Single Wire, 2 Core + Screen
- Construction: Multi-Strand Pure Tin Plated OFC
- Diameter: 3.4 mm
ken4141- New Member
- Number of posts : 10
Registration date : 2022-09-19
» Supra Ply 3.4 - 5 meter a pair SOLD
» Audionote Lexus Speaker cable - 2.5 meter pair, spade, Audio note top of the line copper cable
» Nordost Frey speaker cable - 1.1 meter pair
» Lat International SS 1000 D speaker cable - 5 meter pair
