Audio Research Reference 160M monoblock power amplifier (used)
Audio Research Reference 160M monoblock power amplifier (used) Empty Audio Research Reference 160M monoblock power amplifier (used)
Post by YUAN Tue Feb 20, 2024 6:36 pm
Tube complement: Two matched pairs KT150; two 6H30
Power output: 140 watts continuous from 20Hz to 20kHz
THD: Typically 1% at 140 watts, below 0.04% at 1 watt, 1kHz
Power bandwidth: (–3dB points) 5Hz to 70kHz
Frequency response: (–3dB points at 1 watt) 0.5Hz to 110kHz
Input sensitivity: 2.4V RMS balanced for rated output
Gain: 25.5dB into 8 ohms
Input impedance: 300k ohms, balanced; 100k ohms, single-ended
Output taps: 16 ohms, 8 ohms, 4 ohms
Damping factor: Approximately 14
Overall negative feedback: 14dB
Slew rate: 13 volts/microsecond
Rise time: 2.0 microseconds
Dimensions: 19.0″ x 10.25″ x 18.5″
Weight: 56 lbs. (net) per amp
CONDITION : LIKE NEW
PRICE :RM75000(NETT)
YANG 018-9742567
YUAN 016-5368723
Audio Research Reference 160M monoblock power amplifier (used) Img_2407
Audio Research Reference 160M monoblock power amplifier (used) Img_2408
Audio Research Reference 160M monoblock power amplifier (used) Img_2409Audio Research Reference 160M monoblock power amplifier (used) Img_2410
Audio Research Reference 160M monoblock power amplifier (used) Img_2411
YUAN
Number of posts : 135
