Audio Analogue Crescendo Integrated Amplifier - Made In Italy
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Empty Audio Analogue Crescendo Integrated Amplifier - Made In Italy
Post by raymond88 Sat Mar 02, 2024 7:42 pm
Item: Audio Analogue Crescendo Integrated Amplifier - Made In Italy
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original remote control
Price: RM2300 RM1900 or swap/topup
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Audioa15
Crescendo AMP by AIRTECH has on output power of 50W on a 8Ohm impedance and 80W on a 4Ohm impedance with a THD+N of less then 0.05%. The SNR is more than 100dB and the band-width more than 150KHz. Crescendo AMP by AIRTECH is a High End product in all its parts. The cooperation with AIRTECH has helped to make a unique a products that was already very good: the changes and technologies used in some key points of the circuit are mainly related to the wiring, cables used are 7N OCC in pure copper, the same used for the production of AIRTECH cables, adding Wima capacitors for better filtering and decoupling of the states. These changes effectively allow a significant improvement of sound performance on all parameters and mainly in micro detail and the three-dimensionality of the sound stage. The sound is more open, listening is more pleasant, never tiring thanks to better “musicality”.
The Crescendo AMP by AIRTECH has also been designed to be really very versatile:
• It has 5 Line Inputs and a frontal input to be connected to a portable player. It also has a REC Out and a Phone Out.
• The LINE Input 5 can be configured in By-Pass mode to easily place the Crescendo AMP by AIRTECH in an audio video system, in such a configuration the Crescendo AMP by AIRTECH can drive the front loudspeaker, which can easily be shared between the Stereo-System and the Audio/Video-System increasing also the overall Audio/Video audio quality.
• It is possible to choose the volume scale to perfectly match it to the loudspeakers’ sensibility. 4 different scales are available, 3 of them have been designed for different loudspeakers’ sensibility and the last with 79 steps, 1dB each, for the most precise scale at all, if required.
• Balance function.
• Trigger-In input to be switched-on by the Crescendo CDP by AIRTECH.
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Audioa13
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Audioa16
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Audioa14
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Audioa17
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Audioa18
TECHNICAL INFORMATION
Dimensions: 81 x 445 x 380 mm / 3,2 x 17,5 x 15,0 “
Weight: 10,5 Kg / 23,1 Lbs
Line Gain 6 dB
Power Amp gain 27 dB
Line Input Impedance 40 KOhm
Frequency Response 150 KHz
Noise Level < -100 dBV
SNR > 100 dB
Output Power on 8Ohm Load  50W @ 0.05% THD + N
Output Power on 4Ohm Load  80W @ 0.05% THD + N
Inputs 5 Line Inputs + 1 Frontal Input
Outputs Tape Output + Phone Output + Trigger IN
https://stagaudio.wordpress.com/amps/audio-analogue-crescendo-integrated-amplifier-949/
Number of posts : 10076
Audio Analogue Crescendo Integrated Amplifier - Made In Italy Empty Re: Audio Analogue Crescendo Integrated Amplifier - Made In Italy
Post by raymond88 Sun Mar 10, 2024 2:51 pm
Post by raymond88 Mon Mar 18, 2024 1:31 am
Post by raymond88 Sun Mar 24, 2024 11:43 pm
Post by raymond88 Sun Mar 31, 2024 4:12 pm
