Cambridge Audio CXA61 Integrated Stereo Amplifier (PL)
Cambridge Audio CXA61 Integrated Stereo Amplifier (PL) Used In Excellent Condition. Now Selling At RM3,850. Free Shipping Within West Malaysia.
集成立体声扩音器
The CXA61 is 60 watts per channel of pure excitement. It’s a punchy and upfront listen, without giving away detail or precision - so it’s just as much at home in the mosh-pit as it is the conservatoire.
CXA61 拥有每通道 60 瓦功率,带来纯粹的音乐刺激。真实有力的音乐表现,保留了所有的声音细节与精确度——因此,无论是音乐学院或是摇滚乐区,它都能出色胜任。
LET YOUR MUSIC MOVE YOU
The CXA61 is designed to bring you closer to the music you love. It’s designed to put you right at the heart of your favourite recordings, telling you the story of every note in the most natural, most effortless, most detailed way imaginable. Analogue or digital, lo-fi or hi-res, the CXA61 lets the music take you where you want to go.
让音乐感动您
CXA61 让您更亲近自己喜欢的音乐。让您置身于最喜欢的唱片中,用最自然、最轻松、可想象的最细腻的方式为您讲述每个音符的故事。不管是模拟还是数字音乐,低保真还是高分辨率音乐,CXA61 都能让您畅游音乐的海洋。
UNCOMPROMISED SOUND
The CXA61 has been engineered, refined and finessed with only one objective in mind: to deliver the most thrillingly musical sound you’ve ever experienced. Every choice of component, and every engineering decision, has been made in order to minimise colouration of the sound and maximise its accuracy. Cambridge Audio has drawn on every one of its 50 years of experience to make the CXA61 its most accomplished integrated amplifier yet.
毫不妥协的声音表现
CXA61 经过精心设计,精炼和精雕细琢,目的仅在于一个目标:让您听到最震撼的音乐声音。每个组件的选择以及每项设计决策,均致力最小化声染色并提升精准度。Cambridge Audio 借鉴其 50 年的经验,使 CXA61 成为迄今为止集大成于一身的扩音器。
ALL OF THE MUSIC
Because it’s designed to deliver the maximum musical experience no matter where the music is coming from, the CXA61 has an entirely reengineered digital board featuring the industry-standard ESS Sabre ES9010 K2M digital-to-analogue convertor. The CXA61 can bring digital audio files up to state-of-the-art 32bit/384kHz and DSD256 resolutions vividly to life, combining convenience with performance in a way unheard-of until now.
所有音乐
CXA61 拥有重新设计的数字板,配备行业标准的 ESS Saber ES9010 K2M 数模转换器,无论是何种音乐源,均致力提供最佳的音乐体验。CXA61 可生动逼真地地呈现最先进的 32bit/384kHz 和 DSD256 高解析音频,以前所未有的方式将便捷性与声音表现结合为一。
POWER WITHOUT CORRUPTION
An oversized toroidal transformer gives the CXA61 a muscular 60 watts of power for each channel. Painstaking engineering gives it super-low levels of distortion and supreme electrical efficiency. The result is an amplifier with limitless reserves of power, ready to maximise the dynamic potential of any loudspeakers and able to play at any volume level without stress or distortion.
无损品质
超大号环形变压器为 CXA61 的每个通道提供了 60 瓦的强劲功率。反复专研的工程设计使它具有极低的失真度和极高的电力效率。最终成就一款拥有无限动力储备的扩音器,可以最大程度地发挥所有扬声器的潜力,无论在任何音量下播放都轻松自然,毫不失真。
COMPLETE MUSICAL FREEDOM
Pair any Bluetooth device to the CXA61 to stream up to aptX HD-quality audio. Because there’s no need to compromise your musical experience when you decide to cut the cord.
绝对的音乐自由
将蓝牙设备与 CXA61 配对,播放 aptX HD 品质音频。无线聆听音乐时也无需牺牲您的音乐体验。
SONIC INTEGRITY
The CXA61 features a reimagined power amp stage with optimised capacitors values, and a revised volume pot designed to offer minimised crosstalk. The result is a clean, short and pure signal path that allows your music unmatched coherence - at any volume.
完整音质
CXA61 具有经过重新设计的功率放大器以及优化的电容值,并修改了音量调节器,旨在减少串扰。最终带来干净、简短而纯粹的信号路径,让任何音量的音乐都能保持无与伦比的连贯性。
PARTNER FOR LIFE
The amplifier is the heart and the engine of any system - and the CXA61 is able to power your favourite speakers and form the centre of your musical experience for years to come.
生活的好伙伴
扩音器是所有系统的心脏和引擎——CXA61 能够出色支持您最喜欢的扬声器,并成为您未来多年的音乐体验中心。
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
POWER OUTPUT
60W RMS into 8 Ohms, 90W RMS into 4 Ohms
DAC
ESS Sabre ES9010K2M
FREQUENCY RESPONSE
<5Hz– 60kHz +/-1dB
ANALOGUE AUDIO INPUTS
4 x RCA, 1 x 3.5mm MP3 input (front panel)
DIGITAL AUDIO INPUTS
1 x S/PDIF coaxial, 2 x TOSLINK optical, 1 x USB audio, Bluetooth (integrated)
COMPATIBILITY
TOSLINK optical: 16/24bit 32-96kHz PCM only, S/PDIF coaxial: 16/24bit 32-192kHz PCM only, USB: audio profile 1.0/2.0 (default 2.0), up to 32bit 384kHz PCM, up to DSD256 or DoP256, Bluetooth: 4.2 A2DP/AVRCP supporting up to aptX HD (24bit 48kHz)
BLUETOOTH APTX HD RECEIVER BUILT-IN
Yes
ROON TESTED
Yes
OUTPUTS
Speakers A+B, 3.5mm Headphone, Preamp Output, Subwoofer Output
REMOTE CONTROL
Yes
MAX POWER CONSUMPTION
600W
STANDBY POWER CONSUMPTION
<0.5W
DIMENSIONS (H X W X D)
115 x 430 x 341mm (4.5 x 16.9 x 13.4”)
WEIGHT
8.3kg (18.3lbs)
CXA61
INTEGRATED STEREO AMPLIFIER- 60 Watts per channel with Class AB amplification for detailed and powerful audio performance
- High Quality DAC - Connect digital sources directly via TOSLINK and Coaxial
- Bluetooth aptX HD built in for a high quality wireless connection
- 4 x RCA Analogue connections for all your sources.
- USB Audio Input accepting up to 32bit/384kHz & DSD 256 digital files from Mac or PC
集成立体声扩音器
- 每通道 60 瓦,具有 Class AB 扩音功能,可实现细腻而强大的声音表现
- 高质量 DAC - 通过内置的 TOSLINK 和 Coaxial 直接连接数字源
- 内置蓝牙 aptX HD 以实现高质量无线连接
- 4 x RCA 模拟连接,适用于所有音源。
- USB 音频输入高达 32bit/384kHz & Mac 或电脑的 DSD 256 数字文件
CX SERIES 2. THE SOUND OF PROGRESS.
Half a decade after the CX range redefined performance at its price point, it’s time to reimagine, reengineer and reinvigorate. The all-new CXA61 and CXA81 integrated amplifiers build on the foundations laid (and the Awards won) by CXA60 and CXA80, but with a fresh and progressive perspective.The CXA61 is 60 watts per channel of pure excitement. It’s a punchy and upfront listen, without giving away detail or precision - so it’s just as much at home in the mosh-pit as it is the conservatoire.
CX 系列 2。进步之声。
CX 系列以其卓越的性价比重新定义声音呈现至今已有五年之久,是时候进行重新的演绎与设计,以焕发全新活力。 全新 CXA61 和 CXA81 集成扩音器立足于 CXA60 和 CXA80 的基础(及其赢得的奖项)之上,但又呈现了崭新的进步。CXA61 拥有每通道 60 瓦功率,带来纯粹的音乐刺激。真实有力的音乐表现,保留了所有的声音细节与精确度——因此,无论是音乐学院或是摇滚乐区,它都能出色胜任。
让音乐感动您
UNCOMPROMISED SOUND
毫不妥协的声音表现
ALL OF THE MUSIC
所有音乐
无损品质
绝对的音乐自由
SONIC INTEGRITY
完整音质
PARTNER FOR LIFE
生活的好伙伴
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
POWER OUTPUT
DAC
ESS Sabre ES9010K2M
FREQUENCY RESPONSE
<5Hz– 60kHz +/-1dB
COMPATIBILITY
Yes
ROON TESTED
Yes
OUTPUTS
REMOTE CONTROL
Yes
600W
<0.5W
WEIGHT
8.3kg (18.3lbs)
www.stylelaser.com.my
- Number of posts : 1336
» Cambridge audio CXA61 amplifier
» cambridge audio CXA61 new amplifier
» cambridge audio CXA61 amplifier
» Cambridge Audio Stereo Integrated Amplifier A500
