Audio Research LS7 Pre-amplifier (Used)
One unit of used Audio Research LS7 valve Pre-amplifier for
sale. All valves have recently been changed with new sets. Good condition 8/10. Made in the USA.
Frequency response : ± .5dB, 1.0Hz to
100kHz -3dB points below 0.1Hz and above 300kHz.
Distortion (THD) : Less than .01% at
2V RMS output. (Typically .005% in midband).
Gain : Main
output - 13dB unbalanced
Input impedance : 100K ohms.
Output impedance : 200 ohms main output.
Recommended load 60K ohms and 100pF (20K ohms minimum and 1000pF maximum)
Rated outputs : 2V RMS 1Hz to
100kHz, all outputs, 60K ohm load (maximum output 25V RMS at 1/2% THD into 100K
ohms)
Tube complement : (4)
6922/E88cc dual triode
Weight
: 9.8 lbs. (4.5 kg) Net, 18.8 lbs. (8.5 kg) Shipping
Price RM2890 (negotiable). Location in KL. Please call
019-9578118 Sham for those who are interested.
syam09- Regular
- Number of posts : 74
Registration date : 2009-02-13
» Audio Research I/50 Integrated Amplifier (Used)
» Audio Research CL-120 Amplifier
» Audio Research Pre Amplifier LS9
» Audio Research LS-Two Tube Pre Amplifier ( Used )
» Audio Research VSI75 Amplifier (Used)
