Bryston 3B-ST dual mono, stereo power amplifier, Canada
Engineered to be physically and electrically rugged, to meet the stringent demands of professionals, many of whom leave their studio amplifiers turned on for years.
While chassis had to be light instead of the audiophile massiveness found in some high-end consumer amplifiers, studio engineers and concert pros continued to favor Bryston amps..
The Bryston 3B-ST stereo power amplifier is a compact, rugged, reliable amplifier
-Output stage in Class AB2.
-In Bryston’s black, finned, rack-mount style
-Gold-plated board-edge connectors on driver and input boards
-2x 225VA toroidal transformers
-Bryston’s unique quad complimentary service circuit which realizes low distortion rate, excellent linearity, and high speed.
-Normal stereo use, or mono in bridged connection.
-THX certified
“Bryston 3B ST was the first amplifier that proved to me that amplifiers do make a difference and that the right amplifier can make the difference.”
“I really enjoyed the 3B ST for its impressively wide and deep soundstage as well as its tight and deep bass.”
120 Watts per Channel at 8Ω
200 Watts per Channel at 4Ω
400 Watts In Bridged / Mono at 8 Ω
True dual-mono design
Bridged operation of single push-pull amplifier
Ground Lift switch
2 pairs of gold-plated, 5-way binding posts
Accepts unbalanced RCA, balanced XLR and 1/4″ phone jacks
Signal-to-Noise Ratio: 100 dB
Total Harmonic Distortion: 0.05 %
Slew Rate: 60 Volts / microsecond
Damping Factor: 500 @ 20 Hz
Power consumption: 680W max
Dimension: W482.5 x D228 x H133 mm
Weight : 10.0kg
RM3,250
Welcome for audition.
Subang Jaya ss 14
**Credit Card accepted
Contact 01261 16917
www.facebook.com/Actsessory/
» Bryston 2B-LP Pro Dual Mono Power Amplifier
» Bryston 4B SST2 Dual-Mono Power Amplifier
» Bryston 2BP-LP Dual Channel (Stereo) Power Amplifier
» Bryston 2B-LP Stereo/Mono Power Amplifier。(Used。)~Sold.
» Primare A32 Dual Mono Stereo Power Amplifier (Used) SOLD
