Sumiko By Sonus Faber S.5 - Subwoofer
Item: Sumiko By Sonus Faber S.5 - Subwoofer
Sumiko is a division of Sonus Faber and Sonus Faber helped design the Rel T-5. I previously owned the REL T-5. The Sumiko uses a 150 watt amp and the REL T-5 uses a 125 watt amp. The Sumiko sub is a little heavier and the dimensions are a little larger. The Sumiko has an auto standby mode, the REL T-5 doesn't (only European versions do). When active, the Sumiko swirly logo glows dimly white and the REL T-5 logo doesn't glow. The sound of the two subs is very similar, but the Sumiko plays a little lower and adds a little more weight to the sound.
Condition: Item is in very good condition.
Price: RM1800 or swap/topup
About the Sumiko S.5
Sounds bigger than it looks
When you hear just how hard the Sumiko S.5 hits, you'd swear there was a really big subwoofer in the room. But this mighty mite would have you fooled. Its modest enclosure actually takes up precious-little floor space while delivering big bass slam. The S.5's grip on the bottom end allows it to generate explosive bass for home theater, as well as precise lows for your favorite music recordings. Plus, its gorgeous high-gloss lacquer finish and solid aluminum feet make it a stylish addition to any room.
Bring your music, movies, and video games to life
The S.5's custom, long-throw 8" woofer is framed in a cast steel basket for superior rigidity and accuracy. It's paired with a powerful, high-current 150-watt amplifier for deep, high-impact bass. You'll feel the rumble of explosions in your favorite Hollywood blockbusters and hear the crowds roar when you score a goal in your favorite game. It's great for music, too, like when you want to really appreciate the deep, sonorous lines of a Bach cello suite.
Flexible connectivity and controls
Sumiko knows that seamlessly pairing the sound of a subwoofer to a stereo or surround sound speaker system can be tricky. That's why they gave the S.5 versatile connectivity and control options.
To enjoy optimum bass quality when playing stereo music, you can use the sub's unique speaker-level connector to hook it to your amp's speaker outputs. Or, use the S.5's dedicated LFE (Low Frequency Effects) input to connect your A/V receiver or pre/pro's LFE output for maximum home theater thunder. The sub even allows you to have both inputs connected at the same time, so no matter what you're listening to you'll hear the best bass possible. Separate volume controls for the speaker-level and LFE inputs allow you to individually fine-tune the bass for music and home theater, so there's no need to turn it up for movies, and then turn it down for music.
Product highlights:
frequency response: 40-120 Hz (-3dB)
150-watt built-in Class AB amplifier (250-watts peak power)
down-firing 8" long-throw, treated-paper cone woofer
acoustic suspension (sealed) down-firing enclosure
continuously variable low-pass 30-120 Hz crossover
phase switch (0-180°)
separate auto power on/off and main power switches
line-level/LFE inputs
speaker-level inputs
separate volume controls for speaker/line-level and LFE input
11-1/4"W x 13-1/4"H x 12-7/16"D
weight: 30.8 lbs.
https://www.crutchfield.com/S-ohCl73irdtd/p_782S5B/Sumiko-S-5-Black.html
https://technotif.com/sumiko-s-5/
https://www.audicoonline.co.za/Sumiko-By-Sonus-Faber-S.5-Subwoofer
» Sumiko By Sonus Faber S.5 - Subwoofer
» Sumiko S.9 Subwoofer by Sonus Faber- Gloss Piano Black
» Sonus Faber Subwoofer ***USED***
» Sold - Sonus Faber Gravis Domus powered subwoofer (Used)
» Used Sonus Faber Gravis B1 Active Subwoofer
