Rogue Audio Cronos Magnum tube integrated amplifier
Rogue Audio Cronos Magnum tube integrated amplifier Empty Rogue Audio Cronos Magnum tube integrated amplifier
Post by TheMachinist Sun Apr 07, 2024 5:55 am
Beautiful Rogue Audio amp designed and hand built in USA 100w 4/8 ohms. 25kg Sounds way ahead of its price, well reviewed and regarded. Comes with remote control.  Serviced by highly trusty good old Well Audio Lab at Burlington Square in 2020, and using the original tube with no rolling.
askign SG$1,900 PM to deal https://www.carousell.sg/p/rogue-audio-cronos-magnum-hybrid-tube-amplifier-1247144894
https://hifiplus.com/articles/rogue-audio-cronus-magnum/
- General Features and Specifications:
- 100 WPC - 20Hz-30KHz bandwidth - 4 and 8 ohm transformer taps - Slow start turn on sequencing - Massive high storage linear (!) power supply - (2) 12AX7, (3) 12AU7, (4) KT120 output tubes - Gold plated RCA inputs - Gold plated binding posts - Machined aluminum faceplate - 4 inputs (phono, line 1,2,3) - 45/60 dB gain phono input +/- 0.1 dB 20Hz - 20KHz - 2W Headphone amplifier - Aluminum remote with volume and mute - Buffered variable outputs (great for subwoofers)! - Active outputs for subwoofer or biamping - 4 RCA inputs (phono, line1, line 2, line3) - All precision components - Heavy (2 ounce) copper circuit board - Full tube cage/cover (optional) - Fully tested, burned-in, and auditioned - Detachable IEC power cord - 18" W x 17.5"D X 6.75" H (actual) - 25" W x22"D X 11" H x 55 LBs (shipping dimensions) - power requirements: 120V/240V - 50/60Hz - Entirely designed and hand built in the USA
Rogue Audio Cronos Magnum tube integrated amplifier Rogue_audio_cronos_magnum_hybr_1691210331_2ae8aedc_progressive
Rogue Audio Cronos Magnum tube integrated amplifier Rogue_audio_cronos_magnum_hybr_1691210331_b529131d_progressive
TheMachinist
Number of posts : 147
Registration date : 2014-11-08
