Luxman C-06α (Alpha) Preamplifier
Luxman C-06α (Alpha) Preamplifier for sale
In good working condition 8/10
Power is 100v so needs a stepdown transformer
Selling for RM6800
Contact Peter 012-3820333
Input Sensitivity / Impedance
CD Balance : 150mV/80k Ω
CD Coaxial : 150mV/40k Ω
Phono Line : 150mV/40k Ω
Line1 : 150mV/40k Ω
Line2 : 150mV/40k Ω
Line3 : 150mV/40k Ω
Line4 : 150mV/40k Ω
Tape1, 2 : 150mV/40k Ω
Output terminal
Output1:Coaxial1(Positive)
Output2 : Balance1, Coaxial2 (Positive, Negative)
Output Level / Impedance Balance : rated at 2 V, max. 20V/16 Ω
Coaxial : Rated at 1 v, maximum 10V/8 Ω
Total harmonic distortion factor 0.008% or Less (1 V Output, 1 kHz)
Frequency characteristic 5 Hz to 100 kHz ± 0.5 dB or less
Signal-to-noise ratio (IHF-A) 110 dB or more
Line phase sensor
Power supply voltage 100 VAC, 50Hz/60Hz
Power consumption 40W
External dimensions Width 444 x Height 120 x Depth 414mm
Weight 11kg
Selling for RM6800
Line1 : 150mV/40k Ω
Line2 : 150mV/40k Ω
Line3 : 150mV/40k Ω
Line4 : 150mV/40k Ω
Output terminal
Line phase sensor
Weight 11kg
- Number of posts : 2533
» Luxman CX-1 moviong-coil pre-preamplifier (Used)SOLD
» Luxman M-06α (Alpha) Power amplifier (sold)
» Luxman Tube Preamplifier CL-32
» Luxman CL35 tube preamplifier
» Luxman CL-38uC Tube PreAmplifier
