Audioquest Thunder High (Variable) Current AC Power Cable 2Meter US Plug
Audioquest Thunder High (Variable) Current  AC Power Cable 2Meter US Plug Empty Audioquest Thunder High (Variable) Current AC Power Cable 2Meter US Plug
Post by stylelaser.com.my Thu Apr 18, 2024 8:29 pm
Audioquest Thunder High (Variable) Current  AC Power Cable 2Meter US Plug Brand NewNow Selling At RM6,399. Free Shipping Within West Malaysia.
Audioquest Thunder High (Variable) Current  AC Power Cable 2Meter US Plug S14
Thunder | High (Variable) Current
Low-Z / Noise-Dissipation 3-Pole AC Power Cable
  • Solid Perfect-Surface Copper (PSC) Long-Grain Copper (LGC) Conductors
  • Uncompressed High-Current Transfer
  • RF/ND-Tech (US Patent # 8,988,168)
  • ZERO (No) Characteristic Impedance (50Hz – 1MHz)
  • 72VDC Dielectric-Bias System (US Patent #7,126,055)
  • Directionally Controlled Conductors
Alternating Current (AC), is a far-from-perfect power source. AC power technology is well over a century old and was never designed to meet the exacting standards of today’s high resolution audio-video components. AC noise is present at the utility source, and is then exacerbated by radio frequency noise that is induced (picked up by the AC power cord) and coupled to the component power supplies and to circuit ground. This creates distortion and low-level signal losses via the “masking effect.” Further, power amplifiers can require immense reserves of transient current for their power supplies to react to and then stabilize during dynamic audio passages. Most AC power cords and power conditioner-regenerators, though helpful to a point, are simply not up to the task.
Power amplifiers present a real challenge for any AC power source, as the transient current requirements (though short in duration) can be many times that of the average (RMS) current consumption. Power amplifiers are also unique from all other components in that the current draw is dynamic, not constant, and it changes with volume and audio signal content. Though many AC power cords may feature low DC resistance to allow for some of this requirement, the characteristic impedance of the AC cable is equally responsible for assuring uncompromised performance. Many premium AC cords constrict or compress the audio transient as their characteristic impedance restricts the transient current.
FEATURES
HIGH PURITY CONDUCTORS - LONG-GRAIN COPPER (LGC) AND PERFECT-SURFACE COPPER (PSC)
A carefully finessed combination of solid high-purity Long-Grain Copper (LGC) and high-purity Perfect-Surface Copper (PSC) conductors prevent strand interaction, a major source of ear fatiguing transient intermodulation distortion. LGC allows a smoother and clearer sound than standard OFHC (Oxygen-Free-High-Conductivity) copper. The astonishingly smooth and pure Perfect-Surface Copper further eliminates harshness and greatly increases clarity compared to OFHC, OCC, 8N and other premium coppers.
RF/ND-TECH (PATENTED RADIO-FREQUENCY GROUND-NOISE DISSIPATION) MINIMIZES CIRCUIT MISBEHAVIOR BY CANCELLING INDUCED RF NOISE
AC Ground wires may provide protection from an electrical short circuit, but they also act as an antenna. Thus, they are subject to induced radio-frequency (RF) noise. This RF noise bypasses component power supplies and is typically coupled directly into a system’s most sensitive audio/video circuits. AudioQuest’s RF/ND-Tech greatly reduces this distortion, yielding unprecedented levels of noise dissipation across the widest bandwidth (range) of radio frequencies possible. Our unique circuit topology uses a common-mode phase-cancelling array, in concert with proprietary dielectric materials which provide additional differential linear filtering. US Patent # 8,988,168.
UNCOMPRESSED HIGH (VARIABLE) CURRENT TRANSFER - THUNDER
With current capacity of 20 amps RMS @ 125VAC 50/60Hz (16 amps RMS @ 220-240VA 50/60Hz), Thunder/High (Variable) Current can withstand current transient peaks many times its continuous (average) RMS rating. This makes Thunder/High (Variable) Current ideally suited for a wide assortment of AC power conditioners, power regenerators, AC isolation transformers, and AC battery back-up devices, as well as any power amplifier, powered subwoofer, powered loudspeaker, powered receiver, or integrated amplifier.
72v Dielectric-Bias System (DBS)
Insulation is also a dielectric that can act like a shunt-filter. Biasing minimizes dielectric-noise and linearizes the filter, significantly improving wide-bandwidth dissipation of induced RF noise.
DIRECTIONALITY
All drawn metal strands or conductors have a non-symmetrical, and therefore directional, grain structure. AudioQuest controls the resulting RF impedance variation so that noise is drained away from where it will cause distortion. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. When applicable, arrows are clearly marked on the connectors to ensure superior sound quality. For most models of AQ cable, the arrows not only indicate the direction that optimizes metal-directionality as part of Noise-Dissipation, but also indicates non-symmetrical attachment of shield and GND in order to optimize full-system performance.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Audioquest Thunder High (Variable) Current  AC Power Cable 2Meter US Plug Trade
Number of posts : 1318
