Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player
Cambridge Audio AXA35 Integrated Amplifier+AXC35 CD Player Brand New. Now Selling At RM4,749. Free Shipping Within West Malaysia.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
POWER OUTPUT 35 Watts (into 8 Ohms)
THD (UNWEIGHTED) <0.01% @ 1kHz, 80% of rated power <0.15% 20Hz - 20kHz, 80% of rated power
FREQUENCY RESPONSE (-3DB) 5Hz - 50kHz
S/N RATIO (REF 1W) >82dB (unweighted)
INPUT IMPEDANCES 47k ohms
POWER AMP DAMPING FACTOR > 50
MAX. POWER CONSUMPTION 260W
BASS/TREBLE CONTROLS Shelving, ultimate boost/cut +/- 10dB @ 100Hz and 10kHz
STANDBY POWER CONSUMPTION <0.5W
INPUTS 4x RCA, 1x Phono, 1 x 3.5mm Aux input (front panel)
OUTPUTS Speakers, Rec Out, USB 5V power
DIMENSIONS (HXWXD) 83 x 430 x 335mm (3.3 x 16.9 x 13.2”)
WEIGHT 5.6kg (12.3lbs)
Cambridge Audio AXC35
THD @ 1KHZ -10DBFS <0.01%
D/A CONVERTOR Wolfson Microelectronics WM8524
GAPLESS PLAYBACK Yes
FILTER 2 -pole Butterworth filter
FREQUENCY RESPONSE (+/-0.4DB) 20Hz - 20kHz
THD @ 1KHZ 0DBFS <0.006%
S/N RATIO, A WEIGHTED >95dB
CROSSTALK @1KHZ <-98dB
CROSSTALK @20KHZ <-95dB
OUTPUT IMPEDANCE <50 ohms
MAXIMUM POWER CONSUMPTION 15W
DIMENSIONS 75 x 430 x 305mm (3.0 x 16.9 x 12.2”)
WEIGHT 4.3kg (9.5lbs)
S/PDIF OUTPUT IMPEDANCE <75 ohms
AXA35
Integrated Stereo Amplifier with (Built-in) Phono-Stage- 35 Watts Power per Channel – for detailed performance at all volumes, ideal for smaller/medium sized rooms
- Built-In Phono Stage – to plug & play a vinyl turntable
- Slim Timeless Design – classic hi-fi size, with Lunar Grey aluminium trim
- Tone Controls – fine-tune sound to compensate for room dynamics
- Digital Display – white LED, clearly shows; source, volume & menus
- Headphone Socket – full size socket for high-quality after-hours listening
- Front Aux Input – 3.5mm socket to easily connect compatible devices
Your Journey into Sound
AXA35 is the ideal amp to begin listening to music and really appreciating it – hearing detail in familiar tunes you’ve previously missed. That’s down to the toroidal transformer it uses, a tech found higher up our range. Choose a pair of speakers to suit your taste, perhaps they’ve been in the family for years or maybe something from our SX Series.Release the Wheels of Steel
The built-in phono stage is the ace up AXA35’s sleeve. It means that you can plug a turntable straight in without any extra kit. Moving magnet (MM) compatibility means AXA35 works with a wide variety of turntables – including that vintage one you’ve had your eye on. Soon you’ll be playing the records you’ve been saving for, and planning what to buy next.Setting the Tone
With separate bass and treble controls, you can fine-tune AXA35’s sound to suit your taste, speakers and room dynamics. The volume level is shown on the LED dot matrix display, and with 35 watts per channel you’ll have plenty of kick for smaller to medium sized rooms.Wired for Sound
AXA35 is a well-connected amp, with no less than 4 pairs of RCA inputs, plus a pair of phono sockets for a turntable and a pair of recording outputs. There’s a rear USB socket for technical upgrades. Hi-fi quality speaker binding posts (connectors), compatible for banana plugs, mean that thick cable connects securely for an authentic sound.Designed for Life
As with the rest of AX Series, AXA35 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look enables an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXA35 can easily slot, and breathe new life, into a much-loved system.AXC35
CD Player- Gapless Playback – ideal for classical pieces, live albums & DJ mixes
- High-Quality Wolfson DAC – ensures the digital information from the disc is retrieved accurately
- Digital Coax Out – for pure digital connection to compatible amps
- Slim elegant design – classic hi-fi design, floating effect wedge front foot, lunar grey finish
- Digital display – classy white LED, clear visible information
CD Sound Comes First
AXC35 is an elegant, gapless playback CD player featuring a high-quality digital to analogue converter (DAC). The integrated Wolfson DAC helps accurately retrieve digital information from your discs, to be output to your chosen amplifier – helping to breathe new life into your CD collection. A digital coax out gives you alternative output options.Spinning Songs
You’ve spent years collecting CDs, so why wouldn’t you want to play them for many more years to come? AXC35 is a CD player that will work with any amplifier or system. It’s even got a digital coax out for a straight digital connection to a compatible amp like our AXR100 or a DAC.Complete Control
AXC35 comes with a remote control, so you can choose exactly what to listen to. Compatibility of AX Series remotes means that you only need one device handy for key commands. Alternatively, you can use the controls on the front of AXC35 to skip tracks and so on.Designed for Life
As with the rest of the AX Series, AXC35 shares our house-style of Lunar Grey minimalist fascia, black steel cabinet and ‘floating’ base. This timeless look allows for an upgrade path through our range. A slim build, in the classic 430mm hi-fi width, also means that AXC35 can easily slot, and breathe new life, into a much-loved system.Interested please feel free to contact:
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
- Number of posts : 1323
» Cambridge Audio AXA35 Integrated Amplifier + AXC35 CD Player + AXN10 Network Player
» Cambridge Audio AXA35 Integrated Amplifier + AXN10 Network Player
» cambridge audio axc35 cd player
