Gryphon Diablo 300 Integrated Amplifier
Item: Gryphon Diablo 300 Integrated Amplifier
Condition: 8.5/10. Item is in like-new condition. No dents or scratches. Comes with original remote control, power cable and wooden crate.
Price: RM43k or swap/topup
Product features
2 x 300W (8 Ohm), 2 x 600W (4 Ohm), 2 x 950W (2 Ohm)
True Dual Mono configuration
Zero negative feedback
Microprocessor-controlled 43-step fully balanced relay volume attenuator for best sonic performance based on a minimalist contingent of ultra-precision resistors
Ultra-short signal path
Minimal internal wiring
Military spec. dual-layer and four-layer printed circuit boards with up to 105 micron copper traces
Dual Mono Holmgren toroidal transformer with vacuum treated core and windings to virtually eliminate mechanical noise
PCB-mounted sockets eliminate wiring and shorten signal path
New, high-speed, discrete single-ended Class A input buffer for best possible sonic performance
Gold-plated Swiss Neutrik XLR sockets for two balanced sources
Gold-plated phono sockets with Teflon insulation for 3 inputs and 2 outputs
Fixed-level AV throughput for uncompromising integration with surround preamplifier
Input level matching to prevent abrupt level changes
Large Vacuum Fluorescent Display for easy legibility
Adjustable display lighting (100%, 75%, 50%, 25%, Off)
Backlit touch-sensitive front panel controls
Optional MM/MC phonostage module
Optional PCM/DSD DAC module with one USB, 2 x SPDIF, 1 AES and 1 optical input
12V DC link input and output
Flash memory upgrades via key fob
Local shunt regulators for optimal noise suppression
Non-invasive protection system
Infrared remote control
Input for external iInfrared receiver
Standard power consumption: less than 0.5 W, conforming to latest EU standards
EU CE approval
Designed and built in Denmark
Product features
EU CE approval
» Gryphon Diablo Integrated Amplifier
» Gryphon Diablo 300 Integrated Amplifier
» Gryphon Diablo 300 integrated amp (used)
» Gryphon Diablo Amplifier (Used)
