KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE
KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE Empty KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE
Post by KS AV SOLUTION Sun Apr 28, 2024 9:23 pm
Another Happy Customer from Alor Setar. 7.1.4 Projector Benq W1700 + LCR K700 Pro + Surround L/R and Surround Back L/R A50 x 4 + Amp Lexicon RV-6 + Starke Power Amp A8S + Subwoofer M&K X15 + Atmos M&K IC95 x 4pcs (7.1.4).
No Bass after Auto Calibration / No Audio Effect After Auto Calibration / No Atmos Field after Auto Calibration / No Surround Sound Effect after Auto Calibration / Headache after increase the volume / The picture too watch out and no clarity too ....This are few complaints from the customer.
He find out Us - KS AV SOLUTION from friends and introduce to Him. He made a right choice... Otherwise He is planning to upgrade the speakers...
This are Before and After calibration some data ...if wanted to find out more just call 0194004551.
KS AV SOLUTION
- Full Setup Home Theatre System
- Audio / Speakers Calibration
- Video/ Projector /TV Calibration
- Home Theatre Diffuser & Acoustic Treatments
- New Remote Calibration Available - T&C Applies. RM650.00 / SDG250
Our Scope & Service ( Dirac / ARC / Audyssey / Trinov Audio )
1 - Troubleshoot Your Home Theatre System.
- We have advance software and gadgets to inspect and verify your Home Theater system. It can help you to indentify if there are any upgrade needed to your system. Call for more info.
2 - Diffuser & Room Treatments
- We can detect if your room frequency are in optimum performance in your MLP. This will help you where to fix any room treatments if needed. We can't simply add room treatment it will overkill the performance of your setup.
3 - Subwoofer Placement - Very Critical Part in Home Theater system.
- We will optimize your Subwoofer placement . It will help to get overall Room Target and best performance for your System.
4 - We provide guidelines where to place your speakers after performing frequency test in your room or hall. This can help to minimise your expenses .
Note : KS AV SOLUTION will absorb the transportation charges. Take this opportunity and fire up your Home Theater. Get special packages if took both Audio & Video Calibration. Call now : +60-19400 4551
May 2024
Northern States
03-05-24 - 2 Available
04-05-24 - 1 Available
Ipoh / KL/JB
11-05-24 - 1 Available
12-05-24 - 1 Available
Singapore - SGD250
18-05-24 - 2 Available
19-05-24 - 2 Available
Singapore - SGD250
25-05-24 - 2 Available
26-05-24 - Fully Booked.
Full Speaker Calibration. Our calibration is based on :
- Full Flexibility on the Target Curve , Smoothing and Windowing choices , correction frequency range vs none or only available with paid apps.
- Perfect timing (cross Correlation ) and Volume level (octave range centered around the frequency) adjustment of each and every speaker in the system including ATMOS height speakers.
- Correct room response measurement by accurate multiple position averaging and alignment.
- Correction of speaker/room response with optimized equalizer band adjustment .
Automation correction fails to correctly determine your speaker configuration, for example, it can make voices sound boomy or thin, or create distortion that makes the system sound harsh. If the system’s designers ignored good audio science, it could end up producing a boring, dull sound—or an unnaturally glaring sound.
A good room-correction system makes the sound more natural and pleasing. The notes in a bassline will have the same level as they do on the original recording. Explosions in movie soundtracks will slam rather than just boom. Movie dialogue will sound more realistic, not harsh, thin, or bloated. The sound may also become more enveloping.
Furthermore, the systems sometimes lack the computing power to make an accurate assessment of the configuration of a speaker system and a room’s acoustics, and/or they lack the audio processing power to make all the needed adjustments. Poorly designed systems often miscalculate the bass capabilities of a speaker and the distance from the microphone to the speaker, resulting in inappropriate subwoofer crossover settings, which can make voices sound boomy or thin, and inaccurate speaker delay settings, which can ruin the sense of envelopment that a good surround-sound system produces.
KS AV SOLUTION
Goal of calibrating the audio system in your home theatre is to get a smooth, even frequency response at the primary listening position. You also want the correct sounds to arrive at your ears at the correct times. In addition to the primary listening position, you should also be able to get good performance at the other seating locations , there is no maximum limit in our calibration. You may go as 15 seating position as wish (T&C Applies). During that process, we will addressed various influences on the final sound, such as room acoustics and speaker placement. . Explosions in movie soundtracks will slam rather than just boom. Movie dialogue will sound more realistic, not harsh, thin, or bloated. The sound may also become more enveloping.
What is the different from other auto calibration / tuning ?
Correcting for those effects requires a solid understanding of physics, familiarity with some key bits of audio research, and a specialized microphone and audio-measurement software. Fortunately, the automatic room-correction system built into your audio components can do the job for you—but unfortunately, not all room-correction systems do the job equally well.
We are specialist in
1. Time align each speakers which Auto Calibration can't do due to its limitation.
2. Multiple settings calibration/ tuning minimum 3(max infinity) multiple microphone points which Auto calibration has its limitation.
3. Cross correlate to get actual room response in more larger seating areas which Auto calibrate has its limitation.
4. Target a Optimum Room Curve/Target for your current setup which other auto calibration has limitation .
Common errors in sound systems that can be corrected:
• Poor dialog intelligibility
• Harsh or anemic sound
• Bass is too loud or too low
• Poor surround effect believability
• Movies lack impact
• Poor clarity
These errors can be caused by:
• Automatic sound calibration
• Poor subwoofer settings
• Poor audio source device settings
• Poor option selections in receiver or preamp
• Poor surround mode selection in receiver or preamp
• Poor speaker placement
• Poor speaker level balance
• Poor frequency response
• Speakers out of phase with others
• Subwoofer out of phase with speakers
• Wiring errors
TV / Projector Calibration - Guaranty save the lifespan of your TV/Projector from our Professional Calibration.
- Adjusting Contact, Brightness, Sharpness , Color, Tint, Backlight, and other functions on your Screen to ensure the best Viewing experience.
- We use our years of experience and professional equipment to surpass the ISF calibration industry Standard. We not only match primary colors - Red, Green, and Blue, but we also match secondary colors - Cyan, Magenta, Yellow and adjust the Grayscale to crea
te a highly realistic and lifelike colour reproduction.
KS AV SOLUTION Professional Speaker/TV/Projector Calibration.
Audio & Home Theatre Audition
37, Jalan Villa Tanjung Permai 3, Villa Tanjung Permai Batu Kawan. Bandar Cassia . Batu Kawan. Penang.
Do Visit us for a more full Theatrical experience.
Person to Contact : 019-400 4551
https:=AZWqTN8CXby9OUgV8jP77f06WlVqiZU-LIuwge2WD0ufbArbQ0ut3kki34bs-51DrVEtnXM52zcdeUFxoCIN72hlpoQLrJiIcyov78r_7_6zsWW1-xWcbc91VyPy6UUBWEK7mypZZOfnNtb7QiL_XWG1kEoA4MuBokIOoAcdB5iRzA&__tn__=-]K-R]www.facebook.com/KSAVSOLUTION
KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE 5a02f210
KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE 8d763010KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE De911810KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE Chong_11
KS AV SOLUTION WHOLE MALAYSIA & SINGAPORE Chong_10
KS AV SOLUTION
KS AV SOLUTION
Number of posts : 25
Registration date : 2023-12-15
