Emotiva XPA-5 (5 channel 200W Power amp) (used)
Selling 1 unit of used Emotiva XPA-5 power amp (230V) - 200W/ch
Bought Dec 2009 (so it still comes with 4 years transferable warranty)
Condition: 8.5/10
Age: 8 months
Price: RM3,200
[*]Number of Channels: 5
[*]Signal to Noise Ratio:
1 watt: >97db
Full Power: >111db
[*]Input Impedance: Unbalanced – 23.5kohms
Balanced – 33kohm
[*]Transformer Size: 1,200VA
[*]Secondary Capacitance: 60,000uF
[*]Output Devices: 6 per channel
FEATURES:
Condition: 8.5/10
Age: 8 months
Price: RM3,200
1 watt: >97db
Full Power: >111db
Balanced – 33kohm
- Topology: Fully Discrete, Dual Differential, High Current, Short Signal Path Class A/B
- Power output (all channels driven):
300 watts RMS @ 4 ohm (0.1% THD)
200 watts RMS @ 8 ohm (0.1% THD) - Power Band Response 20 Hz to 20 kHz with less than .05db deviation at rated power
- Broadband Frequency Response (-3db): 5Hz to 150kHz
- Amplifier Gain: 32db
- Size: 17” W x 7.75” H x 19” D
- Weight: 66 lbs (86 lbs boxed))
FEATURES:
- Fully protected from all fault conditions
- Advanced microprocessor operating system
- Soft start circuitry
- External trigger turn on
- Soft touch power switch
- 4RU chassis w/ solid milled aluminum faceplate
- IEC power inlet, 120/230 VAC configurable
- Output design: Triple Darlington with On output stages
- Differential Drive: Dual Differential input
- Types of inputs: Balanced (XLR) and Un-balanced (RCA)
- Type of outputs: Audiophile quality 5 way binding post
- Display type: Digital status indicators
ronaldjoe- Regular
- Number of posts : 79
Registration date : 2009-07-31
» Emotiva XPA-3 (3 channel 200W Power amp) (USED)
» Emotiva XPA-5 5-Channel Power Amplifier (200w)
» Emotiva XPA5 200w x 5 Channel Power Amp ( sold )
» AudioControl Savoy G3 Multi Channel Power Amp ( 7 Channel x 200w ) ( sold)
» Emotiva XPA5 200w x 5channel Power Amp (SOLD)
