Luxman 1980 PD 272 TurnTable ( Used ) 8/10
DC-Servo Direct Drive Turntable (1980-82)
Good Condition Still Shine ....
Selling For Rm 1800.00
call Libertie 017 234 6116
Description
The Luxman PD272 is a two-speed, manual turntable using a DC servo motor direct-drive system.
Slots are completely removed to eliminate unevenness of rotation caused by electromagnetics, and further provided is a turntable platter of high inertia with which the large mass of the platter weight is distributed around the outer contour.
For the tonearm, a straight type is adopted to eliminate resonance caused by lack of solidity which tends to be found on the tonearm exclusively designed for high-compliance type cartridges.
Driving method: direct-drive
Motor: DC servo brushless and slotless
Platter: 30cm aluminium die-cast 1.8kg
Speeds: 33.33 and 45rpm
Pitch control: +-4%
Signal to noise ratio: better than 60dB
Wow and flutter: no more than 0.03% WRMS
Tonearm: straight arm of static balance type
Effective length: 240mm
Overhang: 15mm
Cartridge weight: 4-11g
Stylus pressure: 0-3g (direct reading)
[img][/img]
Description
Pitch control: +-4%
Overhang: 15mm
[img][/img]
libertie5828- Dealer\Reseller\Trader\Service Provider
- Number of posts : 153
» Luxman PD 444 turntable (used)
» Luxman Turntable
» Luxman PD-291 DD Turntable
» Luxman Turntable
