Belkin PF50 Power Conditioner (opened box)
Power conditioner with Power Control Features.
Ordinary household AC power that is delivered to your home is polluted with “noise” from many sources inside your home, including computers, general electronics, and kitchen/household appliances. The Power Console’s advanced PureFilter Circuitry™ is optimised to remove electrical noise and provide clean and clear power to all of your valuable digital, audio, video, and high-current equipment.
The multiphase PureFilter Circuitry provides true isolation between audio, video, digital, and high-current components. This isolation prevents noise created by components that are already connected to the Power Console from contaminating other connected equipment. In addition, the Power Console contains Advanced Overvoltage Protection, which automatically disconnects power from your equipment when the input voltage reaches a dangerous level, and restores power automatically when the voltage returns to a safe level.
Power Center Control Features
(1) 10 sockets, 1 Front and 9 Rear Socket in 5 Programable Banks
- Socket Banks Always-On
- Socket Banks Switched On (No Delay)
- Socket Banks Switched On After Delay.
Delay : 5,10,15 secs delay. 15 sec delay the recommended delay time for tube amplifiers.This is useful to avoid the loud and occasionally damaging speaker “thump” created when the amplifier voltage is stabilizing. Delay sockets will be powered off in reverse (off first)
(2) Remote AC Operation
Turn Power Console on / off via your preamplifier / receiver equipped with a switched European power socket.
(3) Trigger Out
12-volt DC “OUT” port with 3.5mm jack to control another Power Console or device.
(4) Advance Control and Front LCD Control Panel
A. PureFilter Indicator – shows that the multiphase PureFilter Circuitry
is functioning properly.
B. Volt Meter – displays the input AC voltage
C. Current Meter – displays the output current
D. Socket Banks – display the currently selected bank(s) for monitoring
E. Wiring – indicates whether AC is wired properly, or cross-wired.
F. Earthed – indicates if the PF50 is earthed AC socket.
G. Switched Indicator – shows “Switched” sockets ON or OFF.
H. Timed Delay Indicator
I. Remote Indicator – shows whether the remote function is ON or OFF
J. Remote Button
Unit is Brand NEW, opened for checking only. This is an extra unit recently brought back from overseas.
PF50 Belkin's Top Model is Discontinued and Out of Stock at most stores.
If you can find any PF50, it will be very expensive, one is selling for £649 click here.
Current US 110v model is PF60 click here.
Retail was at RM4,580. see The Star review of same unit here
Selling RM1,700 (including courier to anywhere in West / East Malaysia).
Warranty - Full refund if Damaged by Shipping or any damage with NORMAL usage within 3 days.
Unit already tested working for 3 days.
With original box and all original accessories (see below).
Will provide double packing - original box inside a shipping box.
Payment - Maybank2U or COD Bukit Jambul, Penang
Call (9am to 9pm) or SMS (24 hrs) 012-4837447.
Yong (Mr). Bayan Baru. Penang
Actual unit & box. c/w 3m Belkin SD1000 HiCurrent Shielded AC cable.
Electrical Rating 240V~13A/3120W
Product Weight (kg.) 7.1kg.
Product Dimensions (mm) 435 x 329 x 153mm (LxWxH)
Number of Sockets 10 Programmable Sockets
Cable Length 3M - SD1000
Joule Rating 8750J
Maximum Spike Current 300,000A
Response Time <1 nanosecond
Coaxial Protection 3-in; 3-out
Telephone Protection 1-in; 2-out
Ethernet Protection 1-in; 1-out
Overload Protection Yes
Power Safety Shutdown ≤ 196Vac ± 6Vac / ≥ 264Vac ± 6Vac
Package Contents
• User Manual
• PureAV Power Console PF50
• One Pair of Rack-Mount Brackets
• Remote AC Control Cable
• Remote DC Control Cable (3.5mm jack cable)
• 1.8m (6 ft.) RJ45 Ethernet Patch Cable – For broadband connectivity
• 1.8m (6 ft.) BT Phone Cable
• 1.8m (6 ft.) PureAV F-Type Coaxial Signal Cables for Satellite/Cable TV
• 1.8m (6 ft.) PureAV Coaxial Aerial Cable
• One Sheet of PureAV Cable Labels
Need more info to decide?
Click to Download PF50 PDF User Manual.
Click to Download PF60 PDF User Manual.
(3) Trigger Out
J. Remote Button
Joule Rating 8750J
Package Contents
• User Manual
ckyongs- Club Member
- Number of posts : 38
» Belkin PF50 Power Conditioner (opened box)
» Belkin PF50 Power Conditioner (opened box) SOLD
» Belkin PureAV Home Theatre Power Console PF50 power conditioner (sold)
» Belkin PF30 power conditioner (SOLD)
» Audio Power Industries Power Wedge 214p power conditioner (Used)SOLD
