Mission M60i speakers
Brand new set with warranty card attached. Retail is selling RM2950.00
Introducing the Mission M60i speakers, a compact design, compatible with a range of mini systems and separates, in a choice of finishes to suit your taste.
The M60i's curved shape doesn't just look good, it gives the design greater rigidity, ensuring the performance is free of cabinet distortion, even at higher volumes. Build-quality extends to the materials used, with the employment of a 38mm thick front baffle; whilst magnetic shielding of the magnets inside enables placement of the M30Is near to a computer monitor or television set, without disturbing the picture.
The Mission M60is are a well-built, smartly-finished speaker which deliver in compact hifi and larger home cinema set-ups.
Recommended amp power (watts): 25 - 100 watts (RMS)
Sensitivity (dB): 86
Nominal impedance (ohms): 8
Magnetically shielded? Yes
W x H x D (mm): 180 x 305 x 240
Frequency response (Hz): 60 - 20,000
Biwireable? Yes
Connections: Gold-plated 4mm banana plug/binding posts
Bass port? Rear-reflex port
Drivers: HF: 25mm microfibre dome with neodymium magnet and ferrofluid cooling
LF: 125mm paramid driver with 32mm voice coil
Supplied accessories: Removable grilles
Finish: Beech or cherry finish
Extra: 38mm front baffle and curved cabinet profile.
Also available imported CD's for testing , Wynton Marsails, Burmester, The Sheffield Drum record.
Brand new set now selling at RM2000.00 only kindly call at 012-3282993
Biwireable? Yes
david chong- Dealer\Reseller\Trader\Service Provider
- Number of posts : 319
Registration date : 2009-07-24
» Mission M60i bookshelf speakers
» Mission m60i bookshelf speakers
