Clearaudio Smart Matrix Record Cleaning Machine(new)
new in box pls call libertie 019 3202565
selling at Rm3300.00
Specifications Clearaudio Smart Matrix:
•Weight: 28.6 lbs (13 kg)
•Dimensions: 350 x 350 x 200 mm
•Warranty: 3 Years
•Power consumption: Platter-Motor: 12 Watt max.
•Vacuum engine: 450 Watt max.
•Noise Level: if acrylic cover is open: 84 dB,
•if acrylic cover is closed: 80 dB
The Smart Matrix is a Record Cleaning Machine with a high torque motor providing bi-directional rotation of the metal platter, manual fluid application and vacuum pick up. The enclosure is a water resistant, aluminum laminated construction. To prevent leaking, the fluid tank is equipped with a sensor to shut off the machine if the level is too high . The vacuum engine is equipped with an overheat sensor. Noise levels with this machine are the lowest in its class.
The updated model features a work surface that is completely clear of the top of the machine for easy access to your record during cleaning. A convenient lift-off acrylic cover is included
•Warranty: 3 Years
libertie5828- Dealer\Reseller\Trader\Service Provider
- Number of posts : 153
» Clearaudio Smart Matrix Record Cleaning Machine SOLD
» Clearaudio Smart Matrix Record Cleaning Machine (sold)
» Clear Audio matrix record cleaning machine (Reduced)
» WTB: VPI Record cleaning machine.
