Yaqin CD1 Tube Buffer (used)SOLD
am
Item: Yaqin CD1 Tube Buffer
Condition: 8.5/10. In excellent condition. Hardly used since upgraded. Comes complete with original box and packaging and power cord. Will throw in additional 2 nos tubes FOR FREE from Siemens and Zaeux which is much better & expensive than the original tube provided. Pic as below:
Price: SOLD
Contact: Raymond 012-3816611
Some Info:
Yaqin CD - 1 Tube Buffer
The Yaqin tube buffer is based on the 6DJ8 / 6922 tube and is guaranteed to add the magic of tubes to any system without adding any significant noise or distortion. The Yaqin tube output stage can be added to any system; perfect behind any digital player, in a tape monitor loop or between your preamp and amp. Turn your IPOD, CD or any other affordable digital player into the tube-hybrid player of your dreams. Add it between your amp and preamp or into a processor or tape loop and hear every single source component come to life in a spectacular way. Once in place, you will hear an added level of richness, warmth and musicality previously attainable only with a tremendous investment in world-class tube gear. The Yaqin Tube Buffer Stage is the easiest way to upgrade your system.
The Yaqin CD1 uses the twin triode 6DJ8/6922 tube where only one high quality tube is required. Using only one tube makes it easier for you to try out other tubes. 6922 tubes are standard and easily available.
Recommended Usage:
* On the output of a CD player.
* On the “Line Out” of the IPOD
* In the tape loop of an integrated amplifier.
* Between a pre and power amp.
Specifications :
Support Vacuum Tubes >> 6N1, 6N11, 6DJ8, 6922
Input sensitivity: 0.55V
Frequency response: 5Hz~500KHz(-1dB)
Harmonic distortion: ≤0.15%(1KHz)
S/N: ≤60dB(A)
Input Jack: RCA for L&R
Output Jack: RCA for L&R
Weight: 1.9kg
Size: 250 x 185 x 210 mm
Power supply: 110V-120V,220V-240V 60/50Hz
Review:
http://www.stereo.net.au/forums/showthread.php/18340-Yaqin-CD-1-Tube-Buffer?p=289953
Thank you very much.
Price: SOLD
Some Info:
Recommended Usage:
Specifications :
S/N: ≤60dB(A)
Weight: 1.9kg
Review:
Last edited by raymond88 on Wed Apr 13, 2011 3:03 pm; edited 1 time in total (Reason for editing : SOLD)
» (Sold) - Yaqin Tube Buffer
» Yaqin CD1 Tube Buffer (used)SOLD
» Yaqin Tube Buffer (Used)SOLD
» Yaqin CD1 Tube Buffer (used) SOLD
» Yaqin tube buffer (SOLD)
