Musical Fidelity integrated amplifier X-80 (demo)
Letting go my demo unit Musical Fidelity X-80.
Just demo when customer want to listen to it than put back into the box.
Very good condition like new.
Specification:
Output : Voltage RMS : 21 Volts 20Hz to 20kHz, one channel loaded
Peak : 59 Volts
Power : 55 Watts one channel into 8 Ohms (17.4dBW)
85 Watts one channel into 4 Ohms
Peak-to-peak output current : 28 Amps
Damping factor : 77
Output devices per channel : 2
Pre-output impedance : 50 Ohms
Line inputs :
Total harmonic distortion + noise : < 0.02% 20Hz to 20kHz
Signal / noise ratio : > 93dB ‘A’-weighted
Input sensitivity for 55Watts, 8 Ohms : 175mV
Input impedance : 220k Ohms
Overload margin : 29dB
Channel separation : > 55dB typical
Frequency response : 20Hz to 20kHz, + 0, - 0.4dB
Input facilities : 4 pairs line level RCA connectors
Output facilities : 2 amplifier channels via 1 pair per channel binding posts.
1 pair RCA audio outputs controlled by the volume,
1 pair RCA tape record fixed line level output.
Power requirement : 100 / 115 / 230Volts AC 50 / 60Hz (factory pre-set),
190 Watts maximum into 8 Ohms, 15 Watts idle.
Dimensions : 218mm, 8.6 inches wide
98mm, 3.8 inches high (including feet)
339mm, 13.4 inches deep
(including knob and rear terminals)
Weight : 6.5 kg, 14.3 lbs unit only, unboxed
8 kg, 17.7 lbs in shipping carton
Standard accessories : IEC type mains lead (10-Amp), remote control,
2 batteries size LR03 or AAA, manganese alkaline type
Comes with original packaging and remote control.
Condition: 9/10
Original price : RM4700
Now offer : RM3790
Warranty : 6 Month
Interested sms/call : 016-2179777
shahkl2u- Regular
- Number of posts : 53
Registration date : 2010-03-11
» Musical Fidelity MC-2 Speakers & Musical Fidelity B200 Integrated Amplifier SOLD
» Musical Fidelity Elektra E100 Integrated Amplifier & Musical Fidelity Elektra E600 CD Player Made In England (Used)
» Musical Fidelity M3CD CDP and Musical Fidelity M3i Integrated Amplifier
» Musical Fidelity M3i Integrated Amplifier
