WTS:Optoma HD803
WTS:Optoma HD803 Empty WTS:Optoma HD803
Post by hinoyhk Mon Oct 17, 2011 4:48 pm
Brightness 1200 ANSI Lumens
Resolution Native 1080p (1920 x 1080)
Contrast Ratio 8,000:1 (Max)
Image Processing Motion Adaptive 480i, 576i and 1080i De-Interlacing, Advanced 3D Comb Filter, Advanced Noise Reduction and Sharpening
Color Management 10-Step Gamma, User Definable Mode for Different Input and Resolution
Iris Control 16 Step Iris System
Lamp Life and Type Estimated at 3000 Hours, 300W UHP
Display Type Single 0.95” 1080p DMD DLP Technology by Texas Instruments
Throw Ratio (Distance/Width) 1.85-2.22:1 w/o Anamorphic Lens
1.38-1.66:1 w/Anamorphic Lens
Image Size 30” to 300” (0.8 to 7.6 m)
Aspect Ratio Native 16:9, Fully Automatic 2.35:1 w/Anamorphic Lens
Offset 136%
Projection Distance 4.92’ to 32.8’ (1.5 to 10 m)
Keystone Correction ±5° Vertical
Displayable Colors 16 Million
Uniformity 90%
Computer Compatibility UXGA, SXGA+, WXGA, SXGA, XGA, SVGA, VGA, VESA, PC and Macintosh Compatible
Video Compatibility Full NTSC, PAL, SECAM, True HDTV (720p, 1080i/p), 480i/p, 576i/p
Projection Lens F = 2.6 - 2.82; f = 39.12 - 46.94 mm,
1.2x Manual Zoom and Focus
I/O Connection Ports Two HDMI v1.3, DVI w/HDCP, S-Video, Composite Video, Component Video, RS-232, +12V Trigger
Security One Kensington® Lock Port
Weight 10 lbs (4.5kg)
Dimensions (W x H x D) 16” x 4.6” x 12.2” (406 x 117 x 310 mm)
Noise Level 32dB
Storage Temperature -7 - 140°F (-20 - 60°C), 80% Humidity
Operating Temperature 41 - 95°F (5 - 35°C), 80% Humidity
Power Supply AC Input 90-264V, 50-60 Hz
Power Consumption 430W, < 12W Standby Mode
Condition:9/10 (USED 300 hour)
Price:RM3000
Contacts:012-3934810 /hinoyhk@hotmail.my
hinoyhk
Number of posts : 51
Registration date : 2011-06-10
