M2TECH HiFaceEvo (Made in Italy USB to SPDIF Converter) New!
M2TECH HIFACE (USB TO SPDIF CONVERTER)
Complete Line for Your Perusal (From LEFT : DAC,EVO,CLOCK,POWER SUPPLY)
This Post is for the SALE of the EVO Only (2nd from Right - More Pictures Below)
"IF your Digital To Analog converter (DAC) is not up to mark against a top-end 4x Priced Cd Player, i.e Your cd player still conveys better sound than your DAC,Try this Miracle Tool! and establish your DAC at the heart of a top end digital playback system"
HiFace Evo by M2Tech is the new statement in high quality computer audio interfaces. Hosted in a compact and stylish aluminium case, HiFace Evo is capable of flawless transfer of audio data up to 192kHz, 24 bits to virtually every DAC or A/V receiver around, thanks to its comprehensive outputs set.HiFace Evo incorporates the same leading edge technology as the classic hiFace/hiface 2 – with some plus.
HiFace Evo (left) Seen with M2Tech's 32bit 384 DAC "The Young"
Asynchronous operation up to 192kHz is used in conjunction with proprietary drivers which allow for Kernel Streaming, Direct Sound and WASAPI operation (the latter under Windows vista and 7). Windows and Mac drivers are already available. Very high precision, very low phase noise (jitter) crystal oscillators are used. To further improve their performance, these have a dedicated shunt voltage regulator which ensures a very low noise and spurious-free supply. HiFace Evo is powered by an external wall power supply (Included in Malaysia / Not Included Worldwide), to avoid the dirty USB bus supply from negatively affecting HiFace Evo’s performance.
Linear regulators are used all around, to allow all jitter-sensitive digital circuits to operate at their best. Also, a low-pass filter is provided at supply input to further reduce any bad influence from the supply. HiFace Evo can be powered by an External Wall Adapter (9V 1A will fit), or with
7.2V/10.8V Lithium battery (HiFace Supply).
Several outputs are available at the same time: Coax on RCA, Coax on true 75 Ohms BNC, AES/EBU on male XLR, Optical on Toslink™ (Toslink™ is guaranteed to operate up to 96kHz, though we got operation up to 176.4kHz on certain setups), optical on ST (for high-speed operation up to 192kHz and up to 1.6km or 1 mile), straight I2S for direct connection to DIY DACs on RJ-45.
Front Fascia
All outputs, except straight I2S, are galvanically isolated (coax and AES/EBU via a pulse transformer). AES/EBU output can be set to professional or consumer mode by an internal jumper. In addition, an input for an External Clock is available, for those who have a extremely precise and stable clock generator to be used with HiFace Evo. HiFace Evo automatically recognizes the presence of the clock on its input and switches on it whenever available. This input is also galvanically isolated via a pulse transformer. Three LEDs indicate power, external clock presence and incoming data from the PC. Connection to the PC is via a type B female USB connector.
You may add the HiFace EVoDAC for continuous lowest possible jitter combination with HiFace EVO by the combination of joint operation
which is facilitated by I2S connection between EvoDAC and HiFace EVO
A Video Presentation of the HIFACE EVO (in moving pictures)
This is your ultimate STEP UP IF :
- You already own a DAC (Any) and Would Like to Elevate its Sound reproduction, by reducing Jitter.
- If you are unhappy with your DAC's sound as it is unable to reproduce music as good as your CD Player
- Bothered by the rrosion of sound from USB connection
- Your DAC does not have a "World Clock" input, by Adding the HiFace EVO, you are able to add
the HiFace Clock for external operation of clocking (which is now not performed by your computer)
- If you would like to build a complete HIFACE Module consisting of (EVO,EVO DAC,CLOCK, and
HIFACE POWER SUPPLY) for a Monster Reproduction of High End Audio via your Computer at an
affordable price/performance ratio.
- An A/V Receiver (Home Theatre) that has a built in DAC and a SPDIF interface input.
Rear Fascia
Price : RM SOLD 1 Year Warranty and Wall Power Supply
PM For Pre-Order
Front Fascia
Rear Fascia
PM For Pre-Order
quintaruban- Dealer\Reseller\Trader\Service Provider
- Number of posts : 242
Registration date : 2011-02-20
Re: M2TECH HiFaceEvo (Made in Italy USB to SPDIF Converter) New!
For Enquiries from Other States or General/Technical Support
Please Contact 03-78651265
Another Video Link
Limited Units Available
refresh last 2 days before price change.
bump with better internal components for 2014!
bump last few piece!
» M2Tech HiFace ONE (USB to SPDIF Interface Made in Italy) NEW!
» M2Tech hiFace Two USB to SPDIF Converter
» HiFaceTWO (USB to SPDIF Converter) by M2TECH New.
» HiFace® "PocketDAC" by M2TECH 32 bit/384 Khz DAC (New - Made in Italy)
» M2Tech hiFace 24/192 Async USB-SPDIF converter (NEW)
