need advice on NAD power amp
3 posters
need advice on NAD power amp Empty need advice on NAD power amp
Post by azri Sat Aug 04, 2012 2:18 am
seems that i still have my NAD pre amp, why not if i look for a nice decent NAD power amp? theres two options that i've found one is NAD c272, another is NAD 2600a. both priced at a mere $1500, more or less. im pretty sure 2600a is an old gem (hopefully not an old fart) & 272 is a newer breed, still i need u guys to drop some advice which is the best.. tqs heaps
cheers slmt berpuasa to muslim friends What a Face
azri
azri
Number of posts : 1050
need advice on NAD power amp Empty Re: need advice on NAD power amp
Post by puiyk1973 Sat Aug 04, 2012 9:51 am
I have 272 and also 275bbe, great sounding amp for less money.
puiyk1973
Number of posts : 148
Registration date : 2009-12-31
Source(s): AMR cd-777
Amplification: Leben RS100-u and CS1000P
Speakers: ProAc D28
Post by aminmh Wed Sep 19, 2012 4:21 pm
hi, i used to have the c272 but sold it.. now using older 2700 thx. i presume the same sound character to the 2600A.
i can say both have the power and NAD sound character. rich mid open sound.
what can i say with my previous setup, C272 is a bit dry and a bit forward, the 2700thx is more open and vocal a bit clearer but the sound a little laid back from c272. both are very dynamic and can drive 4 ohm speakers.
if the 2600A u can get less than rm 1000 its a steal. but beware because this model has problem with the speaker output relays which may cause cracking and on off sound during initial listening after shutdown..
both runs hot and the longer switched on the better it sounds. just that the older model do not have standby button. so it depends on your preference.. NAD is known for affordable but great sound. my personal opinion.
aminmh
Regular
Regular
Number of posts : 58
Registration date : 2009-03-09
Source(s): cambridge audio 651r cd player, pioneer bdp450
Amplification: Yamaha avr rx A3050,Cambridge audio azur 650r, PS AUDIO HCA 2, NAD 2700THX, NAD T753
Speakers: PSB image series, velodyne,boston acoustic Jamo
