MC-7P Best Tube Preamp ( phono input)
This excellent pre-amp is available at www.analogaudiolabs.com
MC-7P
Original price SGD 1150/-.
Selling Price SGD 1100/-
Some reviews here: 6 Moons Review
Signal to noise ratio: 93 dB
Signal to noise ratio(MM): 75 dB
MM gain: 39 dB
Tubes: 12AX7 X 4 nos, 12AT7 X 1 no, 6P6P X 1 no, 5Z3P X 1 no
Size: 34 cm X 29 cm X 16 cm
Weight: 12 Kg
Call 83195040 if interested
The tube covers (shielders) are coated with 18K gold (since all signal tubes are shielded, the preamp is very quiet -- one of the quietest MM phono preamps). Tube socket and PCB are planted with 18K gold too (no oxide issue here, best contact and connection). All signal wires are pure silver. The circuit design is very complex (Three tubes are used in power supply section in the circuit), Dared engineers and audiophiles worked together to collect best designs available and optimized this one with state-art technologies by computer programs. Here is, you simply cannot get better one with this price, period.
It uses 7 tubes and has two huge separate (yes separate--- only Dared design this way. Simply the best) power transformers: one for high DC volt and one for low volt of tube heaters and others. The capacitors use Audiophile grade and the key resistors use NOS AB and Vishay non-inductive. The tubes come with the amp are Chinese stock Ruby tubes.
Visit www.analogaudiolabs.com for more models
SL-2000
Tube preamp with phono input. Separate power supply module for a improved noise floor.
Selling for 650/-
A simple design but great performance
Class-A
Separate power supply unit
Phono input
Tubes: 6Z4 X 1, 12AX7 X 1, 12AT7 X 1
Size: 22.5 cm X 12 cm X 9.5 cm
Weight: 6.5 Kg (including the power supply)
Call +65 83195040 if interested
MC-7P
MM gain: 39 dB
Weight: 12 Kg
SL-2000
Selling for 650/-
Class-A
Phono input
analogaudiolabs- Dealer\Reseller\Trader\Service Provider
- Number of posts : 263
» MC-7P full tube high-end preamp w phono input,remote,more,best of best
» MC-7P Best Tube Preamp ( phono input)
» Synthesis - Tube phono stage MM input (Brio) (sold)
» Audio Research SP14 Preamplifier with Tube Phono Input
» Triode Corporation TRV-4SE Special Edition Vacuum Tube Preamplifier with MM Phono Input (Used) SOLD
