SINE Power Conditioner / Isolation Transformer / Automatic Voltage Regulator (NEW)
SAF - 30A Power Conditioner RM2700
Features and Specification
> 30Amps Hi-End EMI Filter is employed
> 12 AWG Solid Core Copper is used in internal wiring
> Extra thick Gold plated outlet and IEC male with Cryogenic Treatment
> Damping Material filled inside the chassis to reduce resonance and unwanted vibration
> Equiped with Hi-End Grade Compensation Capacitor
> A Special compensation circuit to enhance the flow the electricity
> 15mm Aluminium Alloy Chassis
> Input Voltage: 100 - 250VAC / 50Hz - 60 Hz
> Maximum Loading: 6600 Watts (220V), 3300 Watts (110V)
> Dimension: (L) 290mm (H) 90mm (W) 125mm
> Net Weight: 5.7 KG
> Gross Weight: 6 KG
> Colour: Black, Silver
SAT - 3KV (V2) Isolation Transformer RM(TBA)
Features and Specifications
> 3000VA (15 Amps) Isolation Transformer
> 4 Pairs Top Quality Duplex Outlet
> Extra thick Gold plated outlet and IEC male with CryogenicTreatment
> Equipped with Hi-End Grade Compensation Capacitor
> 30 Amps circuit breaker with Cryogenic treatment
> 8 mm Aluminium Alloy Chassis
> Dimension: (D) 325mm (H) 270 mm (W) 145mm
> Net Weight: 24 KG
> Gross Weight: 29 KG
> Colour: Silver
SRT - 3KV Automatic Voltage Regulator RM(TBA)
> Automatically adjusts the voltage to the levels that are suitable to your hifi equipment.
> Capacity: 3000VA ( 3000W )
> Input Voltage : 185V - 245V 50/60Hz
> Output Voltage : Select from 205V to 235V
> Response Time : 15-20 mini second
> Output Distorion : No distortion, the same as input waveform
> Protection : Circuit Breaker ( 15A )
> Dimension: (D) 285mm (H) 330 mm (W) 145mm
> Net Weight: 22 KG
> Gross Weight: 26 KG
> Colour: Black
Email [You must be registered and logged in to see this link.] for detail & Special Price. Thank you for viewing.
> Net Weight: 5.7 KG
> Gross Weight: 6 KG
> Net Weight: 24 KG
> Gross Weight: 29 KG
> Colour: Silver
> Net Weight: 22 KG
> Gross Weight: 26 KG
> Colour: Black
Last edited by Skylines Audio on Wed Mar 06, 2013 10:07 am; edited 3 times in total (Reason for editing : CNY Promotion)
Skylines Audio- Dealer\Reseller\Trader\Service Provider
- Number of posts : 185
Registration date : 2012-10-24
Re: SINE Power Conditioner / Isolation Transformer / Automatic Voltage Regulator (NEW)
Bump!
Last edited by Skylines Audio on Wed Mar 06, 2013 10:07 am; edited 1 time in total
Bump!
Hi all, from July 2013 we will adjust Retail Price for SINE products. You will see a slight price increase for some of SINE big Ticket items. Thank you.
COD at Pudu Plaza.
Last edited by Skylines Audio on Thu Aug 15, 2013 10:47 pm; edited 1 time in total
COD at Pudu Plaza.
» SINE Power Conditioner / Isolation Transformer / Automatic Voltage Regulator (NEW)
» SINE SRT-3KV Automatic Voltage Regulator (Used)
» SINE SRT-3KV Automatic Voltage Regulator (Sold)
» Power Bright Full Automatic AC Voltage Regulator
» Right Power SDC-3000 Automatic Voltage Regulator (sold)
