Philips CD 850 mkII cd player (Used)
2 posters
Specifications Philips CD850mk2 :
(http://www.dutchaudioclassics.nl/philips_cd850mk2_cdplayer/)
Line output (Fixed and Variable)
Number of channels: 2
Output voltage: 2Vrms +/-1,5dB
Unbalance left right: max +/-0,6dB
Output resistance: 200 Ohm
Amplitude linearity: max +/-0,2dB from 20Hz to 20kHz
Phase non-linearity: max from 20Hz to 20kHz
Signal to noise ratio: min 95dB from 20Hz to 20kHz
Dynamic range (-60dB): min 92dB from 20Hz to 20kHz
Total harmonic distortion + noise: min 88dB from 20Hz to 20kHz
Intermodulation distortion: min 88dB from 20Hz to 20kHz
Output attenuation: min 60dB
Channel separation: min 100dB from 20Hz to 20kHz
Automatic switched de-emphasis with time constant: 10/50us
Non-linearity on -90dB: +/-2dB
Optical read-out system
Laser type: Semiconductor AlGAas
Wavelength: 780nm +/-20nm
Light output (c.w.): 0,4mW +/- 0,04mW
Variable headphone
Output voltage: max 7,5Vrms +/-2dB
Unbalance left-right: max +/-0.6dB
Output resistance: 150 Ohm
Load impedance range: 32 Ohm to 600 Ohm load
Output power:
max 50W into 32 Ohm load
max 90mW into 150 Ohm load
max 50mW into 600 Ohm load
Dimensions and weight
tray closed (wxdxh): 420x280x90/104mm
tray open (wxhxd): 420x423x90/104mm
weight: 6,3kg
Condition : 7/10 due to age
Made : belgium
Romote : no remote available
Price : RMSOLD
Contact : Raj-0126657671
Variable headphone
Output power:
weight: 6,3kg
Made : belgium
Price : RMSOLD
rasenthiran- Frequent Contributor
- Number of posts : 2536
Source(s): Parasound Zdac/Marantz Cd 63 KI/Sony X505ES/
Amplification: Exposure Super 10/Classe DR-6/Sony TA N90ES/Sansui AU 777 /AU-719/Yamaha RXV-863 Receiver
Speakers: NHT Classic/Monitor Audio Studio 2/Heybrook HB 1
Re: Philips CD 850 mkII cd player (Used)
850mk2 i recomend to my good freind..
朋友 平时不出来! 来什么时候出来,一块玩声音..
Angry_Hifi- Dealer\Reseller\Trader\Service Provider
- Number of posts : 140
Registration date : 2011-11-22
» Philips CD 850 mkII cd player (Used)SOLD
» Philips CD-850 MkII CD player (Used) SOLD
» BLADELIUS THOR MKII AMPLIFIER + BLADIUS FREJA MKII CD PLAYER(SOLD)
» Philips Cd304 MKII cd player (Sold)
» Philips CD 304 MKII TDA1541 CDM1 (Closed) cd player
