Sim Audio Moon DAC 100D 24bit 192Khz
Item: 10/10 Brand New
Country Made: Made in Canada.
What is this: A DAC with USB, TOSLINK And SPDIF input.
USB input BENEFITS : This is the most Cost effective way to Enjoy High resolution Computer Audio files like ( FLAC, AAC, WAV and so on) right from your Seat. It works on MAC too. Resolution up to 44Khz for USB Audio.
TOSLINK And SPIDIF: Have a existing CD player? Dont have enough moolah to upgrade to a new one. Enjoy Moon audio High resolution sound using the PCM 1793 from Burr Brown. And Guess What, many high end CD player, Including Moon Audio uses the same PCM 1793 DAC chip. All you need to do is get a SPIDIF or TOSLINK cable and you can enjoy high resolution sound using you CD player.
At this Price : 1750.00 each,(normal price RM1850.00) i think it is very difficult for you to find a high end product like Sim Audio Moon DAC. Of course there are many China Ones. But this is Made In Canada, and no half here and assembled there. Pure Canadian Made.
Significant Design Features:
· Power supply with 3 stages of DC voltage regulation
· A fully asynchronous sample rate converter
· BurrBrown PCM1793 high-resolution 24-bit/192-kHz D/A and 8X oversampling digital filter
· Accurate digital clocking system for exceptionally low intrinsic jitter levels
· Single-ended RCA analog outputs
· Advanced analog signal path using a DC servo circuit and proprietary analog filter
· Pure copper circuit board tracings with extremely low impedance characteristics
· Extremely rigid chassis construction to minimize the effects of external vibrations
· Accurate matching of high quality components in a symmetrical circuit design
· Designed to be powered up at all times for optimal performance.
Auditions Available. Call 0122908761 Cheong for an appointment.
So to Sum up
Item: Sim Audio Moon 100D DAC
Package includes. 100D DAC and Power Supply.
Price: RM 1750.00 each
Input includes : USB, TOSLINK, SPIDIF.
Resolution : 24bit / 192Khz
Call Now For more information.
So to Sum up
Last edited by sonyman1 on Tue Aug 13, 2013 7:41 am; edited 4 times in total (Reason for editing : new pictures)
sonyman1- Frequent Contributor
- Number of posts : 137
Registration date : 2009-02-20
Re: Sim Audio Moon DAC 100D 24bit 192Khz
Bump for this week. Audio Show coming close so a review is also in Place.
Bump for audio show. KLIAV 2013 Level 7 Room 5 and 6
bump for merdeka
bump for this weekend happy deepavali
bump for chrismas
» Pathos Converto DAC 192KHz/24bit - New in the box
» Pathos Converto DAC 24bit/192KHz - New in the box
» NUFORCE 192khz 24bit DAC
» 24bit 192khz DAC - SOLD
