Cambridge Audio - 651P - MM/MC Phono Stage used sold
Cambridge Audio MM/MC Phono Stage
Condition:8/10
request for serious buyer
Technical specification
Max power consumption: 5W
Gain @ 1kHz: 39dB MM; 55dB MC
Input impedance: 47kOhm MM; 100Ohm MC
Input capacitance: 220pF MM and MC
Nominal output: 300mV MM and MC
Sensitivity for nominal output: 3.35mV MM; 0.5mV MC
Overload margin: >30dB MM and MC
THD 20Hz - 20kHz: <0.005% MM; <0.002% MC
RIAA curve accuracy: 20Hz-50kHz (subsonic filter on off) MM; 20Hz-50kHz MC
Signal to noise ratio (using Audio Precision RIAA-1 with grounded inputs): >86dB MM; >72dB MC
Crosstalk @ 20kHz: >83dB MM; >69dB MC
Dimensions: 1.8" height, 8.5" wide, 5.2'' deep
Weight: 2.0 lbs.
Condition:8/10
Weight: 2.0 lbs.
Chanlau- New Member
- Number of posts : 23
Registration date : 2013-03-14
» Cambridge Audio 651p MM/MC Phono stage SOLD
» cambridge audio 651p phono stage
» Cambridge Audio 640P phono stage (Used)SOLD
» Cambridge Audio Azur 540P-S mm phono stage ( Used ) Sold
» Lenco L75 c/w RB300 & Cambridge Audio 540P phono stage (Used)SOLD
