Reclocking Meridian 506 CDP
5 posters
Reclocking Meridian 506 CDP Empty Reclocking Meridian 506 CDP
Post by mthoi Mon Jun 17, 2013 11:21 am
After reading Wikin and other positing on the CDP upgrades, I finally took courage and embark on a similar DIY project.
My Meridian was having track skipping problem.  I changed the laser lens, but the problem persisted after a few days of use.  I solved this problem by changing all the PSU caps on the servo controller board using Panasonic FCs caps.  While I was at it, I also decided to change all the PSU caps since the CDP is over 20 years old.
It took me a while to plan a DIY upgrade my Meridian 506 CDP. Unlike  some Philips and Marantz CDP, there were not much information on the net on Meridian 506 - no schematics nor modifications. I also contacted Meridian for the schematics, but no avail. The effort was in tracing and studying the circuit and components.
I finally did the following :-
i. Upgrade to Burson dual opamps,
ii. Reclocked using a DIY TCXO clock and shunt power supply
iii. Recaped all the PSU capacitors
iv. Changed the voltage regulators (7805) to LT1085.
Reclocking Meridian 506 CDP Dsc_0812
Reclocking Meridian 506 CDP Dsc_0811
PM me if you have a Meridian schematics, or want to embark on your own DIY project to upgrade your M 506. I would be happy to share with you the schematics and components tracing/values that I have developed in my DIY project.
mthoi
Number of posts : 241
Reclocking Meridian 506 CDP Empty Re: Reclocking Meridian 506 CDP
Post by sph Mon Jun 17, 2013 4:06 pm
Any significant improvements?
Maybe silly of me to pose such a question.
I presume it's obviously a successful upgrade.
sph
Number of posts : 336
Post by Wikin Tue Jun 18, 2013 1:43 pm
Nice work MTHoi; I like that pcb for the clock - components laid out just nice and well implemented.
cheers
Wikin
Wikin
Number of posts : 439
Source(s): PC Audio
Post by kp93300 Thu Jun 20, 2013 6:18 am
Hi MTHOI,
thanks for sharing.  As usual, tidy and neat handiwork !
this reminds me. I have a 20yr krell kps 30i in my store room  waiting for a similiar upgrade.
I am sure you have the next project after this .Post  more pictures .
regards
kp93300
kp93300
Regular
Regular
Number of posts : 98
Post by mthoi Thu Jun 20, 2013 4:00 pm
Hi Wikin, Dr KP,  tx for the encouragement. The next project is to do more work on my TDA1541 DAC - done the PSU upgrade and DEM reclock.  Now looking into tube stage IV with lundahl OPT.  Will update when done.
Reg.
mthoi
Post by mawiaw Sun Sep 29, 2013 2:59 am
tube may be fancy,but lacking too much in BASS department.Think twice!
i perfer stock original although be a littler lesser.
mthoi, after so much of works,how is the final result?
is it worth the effort?
many readers are waiting for your answer?
mawiaw
Number of posts : 14
Registration date : 2013-09-28
