Zu Audio Mission, Mini to RCA interconnect
Zu Audio Mission, Ipod, Mini > RCA interconnect, 1m
Cable Format: stereo (2-channel) within single RF cage with discrete channel leadouts.
Signal Conductor Metallurgy: pure U.S. refined, drawn and processed copper core with direct deposit pure silver skin.
Ground Conductor Metallurgy: pure U.S. refined, drawn and processed copper core with direct deposit pure silver skin.
Shield: 95% high magnitude braid screen is floating at source end of cable terminated/shorted at load.
Cable Geometry: Zu / Gore™ two-channel single-ended transmission.
Signal Wire Geometry: low strand count, perfect lay.
Return / Ground Geometry: low strand count, perfect lay (identical to signal wire).
Dielectrics: virgin white PTFE / all circuits.
Cable Sheath: Nylon
Leadout Sheath: PET
Connector Barrel Metallurgy: brass.
Connector Termination: silver bearing solder / cold forged and sealed, 100% diamagnetic.
Y-out Metallurgy & Makeup: brass.
Directional: set at factory.
Crosstalk: nil, channels are separated by virtual ground barrier.
RF Shielding: high magnitude silver over copper braid + Zu / Gore™ geometry.
Rs Signal: 0.065 Ω
Rs Ground: 0.065 Ω
Cp pin / shield: 130 pF
Cp Signal ch. 1 / Ground ch. 2: 130 pF
Cp ch. 1 / ch. 2: 47 pF
Ls Signal: 1.6 uH
Ls Ground: 1.6 uH
Bend Radius: 1” (25mm)
Cable Diameter: 0.175” (4.45mm)
Leadout Bend Radius: 1/2” (12.7mm)
Leadout Cable Diameter: 0.16” (4.06mm)
L / R Leadout Span: 12” (31cm) standard, custom options available
RCA Barrel Diameter: 0.47” (12mm)
Tolerance: greater than 0.01% on all intra-channel measures
RoHS: compliant
Design: Zu Audio & W.L. Gore®
Manufacturer: Zu Cable Inc. Ogden, Utah
Manufacturers Country Of Origin: U.S.A.
Condition: 8.5/10
Price: Item Sold, Thanks...
Contact: Wong @ +60122117506
Cable Sheath: Nylon
Leadout Sheath: PET
Rs Signal: 0.065 Ω
Rs Ground: 0.065 Ω
Ls Signal: 1.6 uH
Ls Ground: 1.6 uH
RoHS: compliant
Condition: 8.5/10
Last edited by whwong on Sun Jun 01, 2014 6:25 pm; edited 1 time in total (Reason for editing : Item Sold)
whwong- Regular
- Number of posts : 67
Registration date : 2010-07-14
whwong- Regular
» Mission Audio M-Isphere Mini 2.0 Compact Loudspeaker System (New)
» Zu Audio Mission Mk1 RCA interconnect (Used) SOLD
» ZU Audio Mission RCA Interconnect Cable (Used) SOLD
» QED Performance J2P 3.5mm mini-jack to 2-RCA interconnect (New)
