Mission DAC-5 Digital Analog Converter (Sold)
![Mission DAC-5 Digital Analog Converter (Sold) 20130717](https://i.servimg.com/u/f39/16/49/99/58/20130717.jpg)
![Mission DAC-5 Digital Analog Converter (Sold) 20130718](https://i.servimg.com/u/f39/16/49/99/58/20130718.jpg)
![Mission DAC-5 Digital Analog Converter (Sold) 20130719](https://i.servimg.com/u/f39/16/49/99/58/20130719.jpg)
Made In England
beautiful sounding Mission DAC5 (digital to audio
convertor).
It is quite heavy,
made from metal and in gunmetal grey.
Can be used with CD player or cd transport, music
streamer or laptop/pc/mac.
I have used this with various cd players and
transports and have been using it recently in my
project studio hooked up to a macbook.
Great sounding unit - warm yet detailed, clear but
not harsh treble, very detailed midrange and well
defined bass.
Has phase switch which alters sound a little (find
it gives slighty increased bass and solidity)
Description :
The Mission DAC5 has a peculiar design of a black
long narrow box with a single digital input 75ohm
RCA and RCA outputs at the end of it. It adopts
true single bitstream technology with a very high
data rate. The PCB consists of high quality
chipset TDA1547 and SAA7350, SAA7323 as a digital
filter, two AD811 and NE5534 operational
amplifiers, and WIMA capacitors. It has a single
sampling rate of 44.1kHz and uses zero-feedback
twin tube anode output. The interface transformer
between DAC output and analog filtering takes up
the first stage analog filtering task.The Mission
DAC5 has a smooth and clean Bitstream sound that
works very well with computer audio or CD players.
The bass is powerful and brings out its intended
beats accurately.
Specifications:
Interface transformer between DAC output and
analog filtering, taking up the first stage analog
filtering task
Twin tube( 2 5687 triode) anode output,
zero-feedback
18dB 3rd order analog filtering
Tansformer coupling at output for unbalance and
balance output.
Dimensions:
70 x 100 x 283 mm (Width x Height x Depth)
separate analogue and digital power supply
(torroidal tx)
-tda1547 dac fed by SAA7350
-one saa7323 used as a digital filter
-Yamaha input receiver
-2X AD811 , and 2X NE5534 op amps
-Wima caps used throughout
-high quality pcbs
Manufacturer: Mission Cyrus Group, England
Frequency response: 2-20000 Hz Dac7 Chipset
Amplitude linearity: < 0.1 dB
Nonlinear phase: 0.5 at 20 kHz
Usable dynamic: > 100 dB
SNR: > 112 dB (A)
Channel separation:> 100 dB
THD: < 0.001%
Out of band rejection: > 60 dB
Output level: 2 V
Digital input: SPDIF
D/A conversion: 1 bit differential
Power consumption: 10 watts
Dimensions: 7 x 10 x 28.3 cm
Weight: 1.5 kg
Note : This US and Canada Version.
Price : RMSold
Contact : Simon Ting : 012-3612507
Last edited by HiFiLab on Wed Aug 20, 2014 3:44 pm; edited 3 times in total (Reason for editing : sold)
- Number of posts : 2970
BUMP
HiFiLab wrote:BUMP
BUMP
HiFiLab wrote:
UP
» Mission DAD5 CD Player and DAC5 DA Converter (Sold)
» DPA Little Bit Three Digital Analog Converter DAC (sold)
» NAD M51 Digital Analog Converter /Pre (SOLD)
» Roksan ROK-DA1 DAC Digital to Analogue Converter (Used) SOLD
» Audiolab M-DAC+ Digital-to-Analogue Converter (PL) (SOLD)
