Celestion 3000 ribbon speaker with stand (Used)
Celestion 3000, ribbon speaker. Stereophile rated class B speaker with very extended high and tight bass, audition welcome. Excellent condition with original stand. Letting for SIN$750, call (02)9008-0098 and speakers are located in Singapore.
Specifications:
Description: Two-way, sealed-box, stand-mounted loudspeaker.
Drive-units: 21" by 0.5" aluminum-ribbon tweeter, 8" (200mm) polyolefin-cone woofer.
Crossover frequency: 900Hz. Crossover slopes: 3rd-order, 18dB/octave, high- and low-pass.
Frequency response: not specified.
Low-frequency extension: –3dB at 66Hz, –6dB at 49Hz (both free-space measurements).
Sensitivity: 86dB/2.83V/m. Nominal impedance: 4 ohms. Amplifier requirements: up to 100W program.
Dimensions: 25.6" (650mm) H by 13" W (330mm) by 11.8" (300mm) D.
Internal volumes: 28 liters (woofer enclosure), 8 liters (ribbon enclosure). Weight: 43 lbs (19.5kg) each.
Finish: Simulated black ash veneer.
Price: USD$1799/pair (matching K stands cost USD$399/pair)
http:/
/www.stereophile.com/standloudspeakers/590celestion/index.html
Specifications:
http:/
fordpiggy- Frequent Contributor
- Number of posts : 494
» Celestion 3000 ribbon speaker
» Fs celestion 3000 with stand (used)
» DIY Celestion Ribbon Speaker (used) SOLD
» FS Celestion 3000 speaker (Used)
» celestion 3000 standmount speaker(used)
